Holy Anal Probes Batman!
Holy **** Probes Batman!
Geez. I'm working on putting in an LS1 from an '01 Ram Air into my '78 T/A here in CA. This has to be approved by the smog referee once it's done, so I called the referee to get clarifications on a few things. I was expecting they'd be pretty strict, but I was hoping for at least a modicum of wiggle room. It was even worse than I was expecting.
First, he said that I'm going to have to change my entire dash !??!?! He said that since the donor vehicle had a digital dash that I either needed an executive order on the part I was going to use to convert the digital speed/tach to analog, or I'd need to put in the 2001 dash. Are you !@#% kidding me??
It just got uglier from there. I asked about the fact that my cats weren't going to be in precisely the same location as in the '01 for fit reasons. I assured him that all the necessary OBD-II pieces would be hooked up, the sniffer would pass, etc. He said that if the cats weren't in precisely the same location I can't do the conversion. ????
I'm going to try and get hold of another referee because that just seems ludicrous.
You'd think they'd try to help someone do this conversion since the LS1 is like 1000% better for emissions than my '78 400 and like twice as good in gas mileage. But clearly it's not about actual emissions, it's about supporting the bureaucracy.
-Dave
-Dave
-Dave
-Dave
Bingo... move to Nevada - problem solved.
My God! What is it about this state that makes our lives a living hell????
If it passes smog WHO CARES ABOUT ANYTHING ELSE?????
What does the dash have to do with the smog?????
I think that Florida is really starting to look like a good option.
Wow, that sounds like some intense bullcrap right there. Completely agree about it being better for emmisions, obviously, and all that jazz. How could you even expect to put the converters in the same place with a different car? Damn these referees are
Are you sure the dash didn't have something to do with maintaining correct odometer readings? It doesn't make sense that it would be a requirement for smog purposes.
Of course, if you talk to this guy on the phone, he's going to follow the law word for word and err on the side of caution, that's his job. You will probably have more wiggle room on test day.
One day, someone with money to spare will challenge laws like these in court. It makes no sense that you should be held to '01 smog standards instead of '78.
-Dave
Geez. I'm working on putting in an LS1 from an '01 Ram Air into my '78 T/A here in CA. This has to be approved by the smog referee once it's done, so I called the referee to get clarifications on a few things. . .
-Dave
-Dave
Originally Posted by vettezuki
I'm doing a similar conversion for my 82' Corvette. I wouldn't blindly accept (you haven't obviously) what a beaurocrat says, as they have a tendency to rather overstate their power. I remember reading through the vehicle code governing engine swaps about a year ago, and I don't recall a single thing about requirements pertaining to instrumentation. So, when they say something like this, ask them for the section of the vehicle code that defines the regulation. If a law is not stipulated, it does not exist and can not be enforced. As for cats, that's a bit more of a problem. The EPA (Federal) law states quite clearly that one can not in any way move cats from their stock (relative to motor) locations. So I'd try to use the stock manifolds or E.O. numbered units (like B&B Shorties) with correct cats and fabricate around them. If it's a tiny modification to make them fit, something that'd be tough to spot with the eye, you might want to try and fly it through and see if they catch it. I think the worst they could do is send you back without approval.
Here are some official guidelines . . . something is conspicuously missing
http://www.smogcheck.ca.gov/StdPage....s-Jan_1994.htm
Basically your requirements are:
Engine classification must match. Therefore a Gen I -> Gen III SBC is legit.
New Engine/Emission Controls >= year of target vehicle
New Engine/Emission Controls Emission Requirements >= year of "new" engine
This last point is where you'll have trouble if you've relocated the cats.
The only thing the guy might have meant, and he'd be correct, is that you must have a check engine light and diagnostic link when using a computer controlled engine, such as the LS1.
The only point that is a little vague to me would be the fuel evaporative system, as it's not part of the engine assembly, but fuel storage (as I understand it.) Personally, I'd try to pass without attempting to add the evaporative system.
Well I talked to the guy again after he talked to his supervisor. He said the dash thing didn't apply to my case. He said it does for some, when the dash is intricately tied to the computer. It has to do with the diagnostics and that's why it falls under the smog referee. But for this particular conversion, that's not the case. I need to make sure I have all the OBD-II hookups, I need a check engine light (I'm hoping something inconspicuous under the dash is OK) and he said that there is a *very small* amount of leeway in positioning of the cats.
He did say that I needed the evap line so that the OBD-II diagnostics would work correctly. I'm not sure he was positive about that though.
I'm moving forward on the conversion. My car was just delivered today (the restoration was done in PA). And it was dropped off at Synergy Motorsports, who is going to do the conversion for me.
So here's the body:
And here's the new heart:
I think this is gonna be pretty cool!
-Dave
So here's the body:
-Dave
I just took my RX7 with a 2001 LS1 into the ref. You need to have all the stupid smog **** (evap, air, cats,etc..) hooked up and working and need an obd2 port and working check engine light.
The ref I went to was so clueless it was annoying. The first time I left there I passed the actually rolling emmisions test with amazingly low #'s. I wasn't passed because the ******* idiot couldn't "verify" my pcm was the correct one and he didn't believe my carb approved (with sticker) k&n fipk used its own little filter on the air pump intake tube and wanted to see the instructions. I also had 4 readiness tests not set. Right now I just need to get the readiness tests to set and i'm going back and getting mine done.
Hardest part about getting it legal is hooking up the evap, getting the stock cats to fit and the readiness tests/not setting any codes. Hint: there is a way to come up clean in the computer readiness tests without actually having any of the smog **** hooked up. As for the cat locations.. don't tell them anything they dont ask you and play dumb when you go there. If you move them.. make it look stock or wrap it with header wrap or something to hide that you moved them and if they ask just say thats how it was on your donor car. Luckily on my rx7 the stock cat pipes fit with only "some" work.
So here's the body:
-Dave
So here's the body:
-Dave
