Custom turbo build
Old 02-08-2006, 10:18 PM
eli_pem01's Avatar
Default Custom turbo build
I am wanting to build a custom rear mount turbo setup and I would like some advice on what I need to get to have a nice setup with room to expand later if needed. What size turbo...T76, T3, T4? Wastegate...38mm, 50mm? BOV? What size and type piping? Intercooler since its in the rear? What would be the fuel requirements to push 500 rwhp? Thanks in advance.
Old 02-09-2006, 09:24 AM
White.Lightning's Avatar
Search is your friend
Andy
Old 02-09-2006, 10:12 AM
Stupid Boost's Avatar
Go with a T4 (t67),38mm gate from turbosmart and 50mm bov. Piping just keep it the same size as the turbo outlet or maybe 1/2" bigger.
Old 02-09-2006, 11:36 AM
eli_pem01's Avatar
What type of fuel upgrades would I need with that setup?
Old 02-09-2006, 12:00 PM
NA$TY-TA's Avatar
New bigger fuel pump..... bigger injector's.. 42# for now and a good tune.........
Old 02-09-2006, 12:36 PM
eli_pem01's Avatar
Thanks for all the input guys. Also one more thing I'm not sure about is what happens with the MAF when a turbo is installed, how does the car know when it needs the extra fuel.
Old 02-09-2006, 02:44 PM
NA$TY-TA's Avatar
By the MAF..... Unless you max it out wich is very common.........
Old 02-09-2006, 10:39 PM
eli_pem01's Avatar
This may sound stupid but where is the MAF located after installing a turbo. I can't seem to see it in any pics on here.
Old 02-09-2006, 10:45 PM
99camarosupersport's Avatar
act like you are air going into the intake. it's after the air box and it's the only metal box thing before the TB.
Old 02-09-2006, 10:50 PM
eli_pem01's Avatar
Is the stock MAF fine or will I need an aftermarket one? Sorry for all the stupid questions.
Old 02-09-2006, 11:02 PM
my bad man, i thought you just said where is it located i did not realize it said after a turbo install, i'm not a FI guy so i'm not sure. i would assume the same place though i'm sure someone else can help you that actually has a turbo.
Old 02-10-2006, 09:30 AM
NA$TY-TA's Avatar
Around the same area..... but you run into the problem of maxing it...... then your just adding fuel up top and really your tuning blind....... that why people go with aftermarket solutions.... IE BS3, FAST, Mega squirt, MAF T Pro....
