508/452 on a stock 6.0 shortblock! my new dyno results!
Combo is stock 02' 6.0 from a 2500 truck
PATRIOT stage 2 LS6 style castings, with our additional work on the intake (flow 331)
Our custom cam (246/248)
FAST 90/90/ 85mm MAF&lid
ASP,shortbelt, alumn flywheel, almn. driveshaft
9inch w/4.57s, 25/11.5/16 ETStreets on stock wheels,
91 octane pump gas.
This is a dynojet, SAE corrected. I picked up fron 489/447 with the changes being: kooks 1 7/8 from pacesetter 1 3/4, shortbelt, and my re-calibrated ported 85mmMAF.
Still cant find why it drops off so hard at 6700, then bounces back.
91 octane pump gas.
LS1 Tech Administrator
Very strong. Certainly a great combination of parts all working together. Congrats!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Thanks for the props. It did hit my goal. However I did expect more of a gain from the KOOKS. And I expected the car to be a little more peaky with the cam.
Heads are 59cc, so compression is about 11.5. It comes out about the same as the 346, due to the dished pistons.
The pistons have a very small knotch, and unfortuneatly the block is iron, not an ls2. Its a 500.00 core from a junkyard. I knotched the pistons, put in some ARP rod bolts
Originally Posted by Zedzag
I just finished rebuilding my 01 6.0(LQ4) and was looking at getting thaose exact Patriot heads. You just sold me on them!
So you're saying a stock ls1 and stock LQ4 piston is the same dish? Looks like the 59cc chamber is the way to go.
Those heads are awsome, especially for the cost. Ive put down 470+ on stock 6.0s, as well as 5.7s with the stage 2s out of the box, with about 10 degrees less cam than I have.
Def. go with the 59cc chamber.
Originally Posted by gtodoug
how much timing were you able to get away with on 11.5:1 and is this on pump gas as well.
Dougie
Dougie
wow!! I'd love to take a look at that tune. Only reason I ask is that I have my 408 setup at 11.84:1. I'm only running 15-16* now until i get the car dialed in and is being tuned with 93 pump gas.
Dougie
Dougie
Im really liking your low budget approach to making power. You should have put your ported ls2 intake on there just to see the difference man. I'll be doing business with you guys very shortly.
Out of curiousity, what did the intake runner cc out to with the additional port work? And who's hood is that? Looks hella mean.
Nate
Nate
Originally Posted by NOSjohn
I would guess the cam is too big for the motor C.I. and the compression ratio...but those are unknown. So, again...just a guess.
