What stall for nx???
I was originally going to get either a fuddle 3200 or a vig3200. Im going to be running a 100shot nx kit. Aside from the n20 I start getting into my power band around 3000. Im wanting to keep my car streetable and was originally going with a smaller stall. What size stall should I get if im going to be running the 100 shot.
My brother has a 04 GTO and is running a Midwest 3600 2.5 STR converter and it works great. However, he purchased a "Timing Tuner N2O Control Module" from Full Throttle. http://www.fullthrottlespeed.com/ite...~0~Tp~~Bc~.htm
This allows him to do two things. First retard the timing only while engaging the nitrous and second it has a built in rpm window activation. He has his come on at 3800 rpms and shut off at 6100 rpm's. This way during launch and while shifting gears the Trans is not getting as much abuse.
He improved 1.3 seconds from a 100 hp shot.
Good luck,
Al
Good luck,
Al
