How much HP can a stock 4l60e handle?
Old 02-10-2006, 10:51 AM
N20LS1's Avatar
Default How much HP can a stock 4l60e handle?
I have an 02' Camaro ss A4 with bolt ons, but a stock tc + I'm spraying a 175 shot. For how long will my tc or tranny last?
Old 02-10-2006, 11:16 AM
BORN2LOSE's Avatar
I would say not much over 400. I don't think yours will last very long with that size shot. Change the fluid often, get a shift kit and pray a whole lot. You never know though.
Old 02-10-2006, 11:33 AM
Joel_SS's Avatar
Not long a 175 shot
Old 02-10-2006, 12:26 PM
N20LS1's Avatar
Thanks for the info guys.
Old 02-10-2006, 08:55 PM
Board Certified Idiot
Z2K_MrJ's Avatar
Wet or Dry.?? get a tune if you are spraying that much. And is it from a DIG? all 3 play factoers in how long it will last and how often do you spray it. PPl in this site spray 150 with bolt ons on stock trans and still holding up fine.
Old 02-10-2006, 09:26 PM
MiaSSmaro98's Avatar
guys how much can u spray on a wet kit with no tuning?i mean i plan on it using nitrous but i already rebuilt my tranny with rayabestos clutches and kelvar band along witha transgo kit.
Old 02-13-2006, 03:45 AM
Z2K_MrJ's Avatar
i rember i had my wet kit from NX spraying 150. On my LT1 with only Minor Bolt ons and i did not need a TUNE and i was still good with out it.should have ran a fuel pump for safty but did not was still ok. This summer i will be putting the same kit and shot on my LS1. Few buddies i know do it now No problems
Old 02-13-2006, 06:05 AM
flyin red TA's Avatar
My trans started to bounce the limiter before shifting into 3rd with a cam, bolt ons, and a 150 dry. I would say the max a stock trans will take is around 425-450hp, and even then it might not last very long.
Old 02-13-2006, 06:33 AM
GM Muscle's Avatar
Don't spray through the shifts and it will help it last. I'm still on my stock tranny, running a 225 shot. The car has been sprayed hard for more than 4 years.
Old 02-13-2006, 07:00 AM
Restricted User
Automatics's Avatar
As you can see by the replys, you will want to use a "window" switch. This will always help, as to keeping the 2-4 band & 3-4 clutches alive. Without this, the realistic limit is about 450-475HP, there are always exceptions to this, but this is a good rule to follow from experience.
Old 02-13-2006, 02:56 PM
speedo's Avatar
What if you just added a Vaccum Modulator to a stock tranny will it make it last longer? Or just shift faster with the same ending result?
Old 02-14-2006, 03:38 AM
Restricted User
Automatics's Avatar
The vacuum modualtor should help some, especially the 2-3 shift at WOT. But more is needed than just the vacuum modulator. You will need to increase the volume of feed oil to 2nd & 3rd gear. This can only be done by modifying the valve body plate. I would add the larger boost valve from Trans-Go, as this will improve oil pressure & volume.
Old 02-14-2006, 06:27 AM
mramay's Avatar
I'm talking to a tuner (NRP) in Las Vegas and he said that he has done tuning to have a 4L60E handle 600 hp. Hope he's right, I'll be between 475 and 500 into a 4L60E.
Old 02-18-2006, 09:09 PM
JRocket's Avatar
800-900rwhp,turbo for power adder,2900-3000lb car with 3:50-3:70 gear ratio,2800-3200 stall,street/strip car.
How long will the trans last,and what will have to be done to make it last.
Old 02-18-2006, 10:01 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
When I upped to boost and ended with 500+rwhp, the tranny died within a month.
Old 02-18-2006, 11:05 PM
JRocket's Avatar
What does your car weigh? Im thinking I might be able to make the 4l60e live with this light of a car.
Old 02-19-2006, 09:47 AM
3600 lbs.
Old 02-19-2006, 11:19 AM
JRocket's Avatar
My car will be 2900-3000 with driver and fuel,maybe a 600-700lb diet might let the 4l60e live?Im hoping so.
Old 02-19-2006, 01:09 PM
DSG
DSG's Avatar
The most I have run through my TA was about 550rwhp. Its made 6 ten second passes and now its toast.
Powerglide here I come.
Old 02-19-2006, 08:08 PM
chris718's Avatar
the key to making it live betond the normal mods that are made is to take rotating speed out of the trans.this is only acccomplished by replacing the front planetary gearset with a custom one yielding a 2.66 first gear ratio.there only one place doing it and its us.i am currently signing up as a sponsor and will put links to the stuff as soon as the signing up is done so no one gets angry.if your unsure about my tech go back and read some of my posts
Quick Reply: How much HP can a stock 4l60e handle?
