question about fluid and bearings
Old 02-10-2006, 12:03 PM
CamaroSS621's Avatar
Default question about fluid and bearings
I just pulled my 12 bolt axles out because I am putting longer wheels studs in. I figured Id change the rear fluid while im there. IS the royal purple worth the $? How much do I use? Second, I have pressed on bearings and ABS ring pressed on, I took them to a shop to get them pressed off and the studs installed, they said I needed to get a new locker for the bearing and suggest just to do a bearing and locker/keeper. Does anyone know the part # for the bearing and keeper?
Old 02-13-2006, 08:27 PM
anyone??
Old 02-14-2006, 08:15 AM
ok. I got the axles back and its gonna go back together tonight. How much fluid do I use for a full change?
