3.73 Or 4.10?
Old 02-10-2006, 09:03 PM
JS99Z's Avatar
Default 3.73 Or 4.10?
I have a 99 LS1 Camaro A4. I'll be running a 231/237 .589/595 112 with PP 243 stage II heads with a 3500 stall. Which gears would be better for my setup 3.73's or 4.10's? Gas mileage is not an issue.
Thanks
Old 02-10-2006, 11:37 PM
FUN LS1's Avatar
I love my 4.10's. Best mod I ever did for quickness. Like night and day from stock. Although I'm not smart enough to know how to calculate it, I've been told you should gear you car for the cam you choose. With your cam, I'd go big, 'cause you'll still be able to hit a quarter mile at the top of 4th in peak power, say 6000-6300, and that cam tops out around 6500.
You might want 3.73's if you drive a lot of miles, to save some on gas, but why would you have that big cam if that's the case. Also, I've seen some posts that say the 4.10's are not as stong as 3.73's because of the smaller pinion. ...just think of the 4.10's as being stronger than 4.33's, if that helps:-)
Old 02-11-2006, 12:27 PM
Flash99's Avatar
3.73's if you wanna drive it around alot, and not use up major gas. I would say 4.10's if its a race only car, or just a plain out grocery getter. I have seen on here people with great success running 4.10's at the track, and the stock rear holding up.
Old 02-11-2006, 01:38 PM
fasttagurl's Avatar
4.10s definetly. I had 3.73s at first then wanted to go all out so I switched to 4.10s. I have a TC above 4000 and I am AMAZED at what this car can do for a cam-only. I almost have the front wheels off the ground. Go with the 4.10s man!!
Old 02-11-2006, 08:37 PM
FUN LS1's Avatar
4.10's are great on the street. Nothing [like] leaving that 'stang looking at the back of your car getting smaller, fast..., like he's sitting still.
fasttagurl, you've got a nice set of bolt-ons to get the most out of a cam-only set up. Have you had it at the track or on a dyno? What heads are you looking at?
Old 02-11-2006, 08:39 PM
HaulinHawk's Avatar
Love My 4.10s Also!!!
Old 02-11-2006, 08:40 PM
jessedale98's Avatar
410's are the WORST choice i ever made, dropped me 5mph in the 1/4 and I cant get traction to SAVE MY LIFE.
Old 02-11-2006, 08:44 PM
HaulinHawk's Avatar
u are leaving alot of e.t on the table with that soft 60ft.u gotta put the power too the ground!!!!
Old 02-11-2006, 08:48 PM
FUN LS1's Avatar
What tires are you running?
Old 02-11-2006, 08:50 PM
26inc mt et streets
Old 02-11-2006, 08:53 PM
HaulinHawk's Avatar
Try the mt et street radial. 1.56 60ft NA.
Old 02-11-2006, 08:56 PM
How the hell could a radial be better than a slick?
Old 02-11-2006, 09:02 PM
HaulinHawk's Avatar
There are plenty of guys around my part runnin same if not quicker #s with the radial over the slick. Dont underestimate these radials.
Old 02-11-2006, 09:03 PM
Let me know if u find a set for sale! PM ME SUM1
Old 02-12-2006, 06:07 PM
Mac 2002 SS's Avatar
man ,that 4.10 and the 3500 stall is killing your 60ft !! if you don't want to change the gear ,change tire to a 28" slick ! IMHO ......I would change the gear to a 3.73 or even a 3.42 and I'm sure you will see a big improvement.
