what gears does my 99 trans am have?
Old 02-11-2006, 11:49 AM
LSfast1's Avatar
Default what gears does my 99 trans am have?
I have a factory rear end in my 99 Trans Am. it is an a4. what rear gears do i have? are they the 2:73's or 3:23's? thanks
josh
Old 02-11-2006, 11:56 AM
2001NBMZ28's Avatar
Look at the RPO codes on the drivers side door - GU2 2.73, GU5, 3.23
Old 02-11-2006, 12:36 PM
MountainMotor's Avatar
Just watch your rpm's on the highway. If your running around 1600rpm's at 60 then you have 2.73's, if your running more around 1900rpm's then you have 3.23's.
Old 02-11-2006, 12:41 PM
LSfast1's Avatar
thanks guys. i couldn't find the rpo codes on the drivers side door. becasue i don't have the factory DS door. it got dmaged in a wreck. so i'll juts look at my rpm's and see. i'm thinking i have 3:23's though. and if i do how much will it help changing to 3:73's? thanks
josh
Old 02-11-2006, 12:45 PM
2001NBMZ28's Avatar
Good point, double check against a gear/RPM calculator like www.f-body.org/gears/ to be sure. My car says GU2 on the door, but has a "factory" 3.42 rear in it from an M6 car.
Old 02-11-2006, 01:09 PM
3.73's would help but not near as much as a stall. If you do have 3.23's then I'd definately go for the stall first. I'd actually go for the stall first even if I had 2.73's. The gears will help but not as much as a stall in an auto.
Old 02-11-2006, 04:14 PM
LSfast1's Avatar
thats what i had planned on doing. but 'm probably gonna be selling my car anyways. but thanks again for the help guys.
josh
Quick Reply: what gears does my 99 trans am have?
