Pacesetters/Motor mount install?
Old 02-11-2006, 01:30 PM
ashade98's Avatar
Default Pacesetters/Motor mount install?
I'm installing my pacesetters, and on the drivers side I had to loosen up my POLY motor mount to slip that sucker in.
Do I need to re-install the heat shield that covers the motor mount? Wasn't going to bother unless it's critical.
Old 02-13-2006, 05:53 PM
Cstick's Avatar
Pretty sure I left mine in my stock parts pile in the garage.
Old 02-13-2006, 05:55 PM
Keenov's Avatar
Yea, I tossed the heat sheild in both of my cars. No problems.
Old 02-13-2006, 06:00 PM
Redneck Z's Avatar
Doesn't the heat shield protect the alternator from the heat of the longtubes?
Old 02-13-2006, 08:10 PM
Full-Force's Avatar
Junk the heat shield. You probably just needed to swing the steering shaft out of the way instead of fooling with the motor mount. It takes a whole 2 minutes to do.
Old 02-13-2006, 09:45 PM
Tkami129's Avatar
i put the heat shield back on...its not that big of a job and it gives me a peace of mind knowing that it wont affect the alternator
Old 02-13-2006, 10:16 PM
schultzsj's Avatar
I just installed the driver's poly mount and I put the heat shield back in - I still have all the exhaust system shields in place. Since headers produce even more heat than the stock exhaust it makes sense to me to retain them.
Steve
Old 02-14-2006, 08:30 AM
you2slo's Avatar
I took almost all mine off after the header install. I did leave the motor mount shield on. I don't want to replace it just because I wanted to save .5 ounces.
