WHAT LOCkTITE on header bolts
Old 02-12-2006, 01:56 PM
travSS01's Avatar
Default WHAT LOCkTITE on header bolts
Ive heard many people say to apply locktite to header bolts when installing new headers, i purchased the red(perm.) stick type one is this what most people use thankx.
Old 02-12-2006, 02:02 PM
vodas00ss's Avatar
dude, do not put loctite on your header bolts. use anit-sease. your trying to do the exact opposite of what you need.
Old 02-12-2006, 02:03 PM
Bo White's Avatar
I use the factory bolts and put lock washers on em. Never had any issues.
Old 02-12-2006, 02:08 PM
WILWAXU's Avatar
Never used locktite or antisease. Headers have been of the car once, never had to retighten them once after a few heat cycles.
Old 02-12-2006, 02:11 PM
vodas00ss's Avatar
I alwayse use anitsease when putting a bolt into anything aluminum
Old 02-12-2006, 02:39 PM
That's what she said...
TheBlurLS1's Avatar
Anti-sease is the only thing to use.
I'm guessing from reading this that you've never used red loctite before? It takes an act of congress to remove it. Is this somthing you really want stuck in your aluminum heads?
It's a helluva lot easier to retighten some bolts than to pull the heads and re-drill and tap them.
Old 02-12-2006, 02:56 PM
travSS01's Avatar
Thanks guys, that was my first thought about being able to get them off after using it but i have a install guide i printed off the net ....bowlingss.com that said to use it and this guy at lowes also suggested the red loctite too, but ill hold that to a grain of salt next to everyone on this site .... thanks again everyone for saving me on this one
Old 02-12-2006, 02:59 PM
GMmexican's Avatar
personally id get some stronger ARP bolts loose the cheap card board box header gaskets that come with your headers and get some leak proof cooper/aluminum/ceramic ones and just get yourself some header locks from summit.
Old 02-12-2006, 04:15 PM
JonB's Avatar
I've never had a problem removing header bolt with red loctite on them they come out easy. I've done it many times each time is just as easy as the last. This in no 10in bolt its just small bolt just use it sparingly, you don't need to cover the entire bolt just put a dab or two on the bolt to keep it from loosening.
Old 02-12-2006, 06:03 PM
BriancWS6's Avatar
Anti seize and factory bolts here. Have done three installs and have had zero issues using this method.
Old 02-12-2006, 07:43 PM
TheBlurLS1's Avatar
Whats wrong with the stock bolts?
Old 02-12-2006, 08:50 PM
FRCBobby's Avatar
When I installed the headers on my old TA I reused stock bolts and didn't put anything on the bolts
Old 02-12-2006, 08:53 PM
WsSickLs6's Avatar
red locktite...so you can never get them out in one piece again...Either that, or just weld the headers on and toss the bolts...
Old 02-12-2006, 11:23 PM
GMmexican's Avatar
i heard alot of storys about them breaking and stripping and exhaust leak issues
Old 02-13-2006, 12:54 AM
TheBlurLS1's Avatar
Well i've heard alot more stories of them working perfect when cleaned up and installed properly, with some anti-sease.
If anything strips its going to be the aluminum, and wouldnt matter which damn bolts are doing the stripping!
