Electrical Problem
Electrical Problem
99 trans am
new battery
I am having a problem with my drivers window stopping at random times. It will go work for about two seconds then stop for about 10-15 seconds then work again for another two-four. What could be causing this. The passenger window is working fine. The window doesn't roll up slow so I don't think it's the window motor. Could it possibly be a loose ground? I could be driving while this is happening or simply sitting still.
Also, when I shut my car off the oil gauge starts crawling up. Is my instrumentation bad or could this possibly be a loose ground?
If it's a possibility of a loose ground could someone tell me where the ground is so I could check it?
new battery
Originally Posted by white99
99 trans am
new battery
new battery
Welcome to one of the most common Fbody complaints! Your window motor is bad. Here is a good guide to help you. http://shbox.com/page/windowmotor.html
As far as the gauge thing, i have no idea.
*Edit*
Did some searching for ya. It seems that 99's are known for having bad/ ultra-sensitive gauges. Not saying this is your problem, just trying to help. Check these links out.
https://ls1tech.com/forums/showthrea...ghlight=gauges
