How do you re-install.....
How in the heck do you reinstall the harmarnic balancer? I went to chevy, high dollar "snap-on" installer. Didnt fit. Thanks.
The best way is to get a threaded rod, washers and nut. Thread the rod in, then pull it on with washers and nut. If it's really tight - heating it in the oven helps.
Hope this helps.
Hope this helps.
threaded rod is my first suggestion, but if it's as rare to find as it is around here, Napa part number 2801-225 is a longer bolt that will catch 5 or 6 threads in the crank snout - you'll need a couple big washers too
