Pacesetter header problem
It's been colder then crap here in ohio the past few weeks but i got around to "trying" to put the headers on the finish this god forsaken install of stuff i started almost a month ago. So i get to work i already had the headers in the engine bay and i was hanging the drivers header up first problem had all the bolts in except the rear one go to put it in and the header hole isn't even close to where the head hole is. WTF so i try to pry it alittle NOPE still atleast a 1/4 inch from hitting the hole. So i yank the damn thing out and find the flange on the header is bent down slightly and it's not all that straight either on the surface that mates to the head. So i'm going to heat the thing up and try to get it into the right place. I drilled the hole out alittle, the header will bolt up now but i'm afraid it won't seal right. Just a little FYI for you guys might wanna check this out if you buy some pacesetters but i'm prolly the only one this has and ever will have happened too .
I swear this car has fought me since the beginning first the TC bolts didn't want to come out had to cut the head off one, next i chipped the damn crank pulley installing it although that just gave me a reason to buy and underdrive one, trying to put the LS6 intake on broke the oil pressure sending unit, now the headers are giving me fits, lets not forget the PITA oil pump i was worried about tearing the o-ring so it took forever installing it, and the oil pickup tube bolt that ppl. say not to drop it in the oil pan yeah i did but i must be one lucky SOB cause a few cuss words a coat hanger a magnet and 20min's later i some how defied the laws of lost engine bolts and retrieved it . I'm used to stuff being easy and quick like working on my 5.0. I just hope it's worth it and the car doesn't blow up or anything or i'm burning it to the ground . I've had 2 ppl. want me to help with with installs on their LS1's yeah i bet i tackle this kinda project again anytime soon.
The flange could have gotten bent during shipping. Someone had a similar problem with some Kook's awhile back. The header should seal though, that's what gaskets are for. Sucks having issues when installing go fast **** but that's part of the game and something only a gearhead loves when it's all over and you go cruisin'. I had a nightmare of a spring and shock install on a buddy of mines '02 SS.
No this flange didn't get bent from shipping they are solid nothing short of a torch can bend these things. I'm sending them back now they'll take em back cause i rewelded the hole up and redrilled it haha looks like new. BUT the reason i drilled the hole out to begin with is cause i didn't see the flange was bent back about 1/4 inch and kinda twisted down alittle. Saw that after the fact it figures i just thought the hole was drilled wrong. I know these mods will be worth it but god damn is this thing a major PITA. It makes it 10x's worse cause ohio sucks for weather this time of the year 50 one day the next day it's 20 out.
See the flange is as good as new well kinda lol but i don't think their going to complain on how it looks it's better then the hole being wallowed out.
That's what she said...
I've never heard of pacesetters having this problem before....
Keep after it!
I dropped a camshaft retainer plate bolt into the oil pan almost 2 months ago during my cam swap and was able to get it out with a magnet too. I was super carefull with stuffing in rags and using a zip tie and tie wire and **** when i was messign with the pickup tube bolt, and it went in no problem. I was so excited that i got it done, i pulled the rags out, not 3 seconds later, i dropped a retainer plate bolt. It fell between the block and oil pump and went into the pan.
The worst had to have been when my dipstick tube broke off inside the block!
I've also broken 2 valve cover bolts off in the head, broken the coolant temp sensor off in the head.... ok i'll stop now.
Keep after it!
Keep after it!
Keep after it!
But i'm keeping after it sucks i know have this set back on the headers hopefully it'll be warmer next weekend so i can get this bastard done and see how it runs. Should go something like this start it up drive it for a day break everything in, then the next day after its warmed up gas pedal to the floor should =
