tci deep trans pan , what filter
You can use the stock filter.The pan has raised humps for the filter to set on.The only way to use a deaper truck filter is to grind the ridges.I've been using mine for a couple of years with the stock filter replacement and cant see grinding the ridges.
Moderator
I had the deep pand and ground the prongs down to use
the truck filter. Point being that your pickup is now well
below the surface of the juice, so being a pint or two low,
or just cornering like a wild man, will not starve the pickup.
