hitting the rev limiter on the 3-4 shift
Old 02-14-2006, 11:31 AM
LiquidFire350's Avatar
Default hitting the rev limiter on the 3-4 shift
i usually dont go on top speed runs but the other day i was on the tollway coming home at like 1am, so i give a little bit of gas, probably around 3/4 throttle, wasnt flooring it. now ive gone 155+ before so i really wasnt paying attention to the tach or speedo because i know the car can do it, then i hear the motor bounce off the rev limiter, look down and im only going 120-125
last time i ran that fast i still had the stock converter in, now i have a 3600, im thinking that is what caused it and i need to have my shift points adjusted
what do you guys think?
Old 02-15-2006, 06:15 PM
bump
Old 02-15-2006, 08:37 PM
DeltaT's Avatar
Yeah, you should adjust your shift points so you don't hit the limiter, or raise the limiter point if revving that high is doing you any good.
Jim
Old 02-16-2006, 08:43 AM
SgtB's Avatar
How many miles on your tranny Matt?
It could be the rev limiter needs to be raised or that your 3-4 clutch packs are going.
Old 02-16-2006, 01:43 PM
mikey's old trans, he said its got about 9K on it, and its been "refreshed"
Old 02-16-2006, 02:10 PM
flyin red TA's Avatar
Well if you keep raising the limiter and you're still hitting it, the clutchpacks are done. Also, a WOT shift from 3-4 is about the worst thing you can do to a stock 4l60e.
Old 02-16-2006, 02:47 PM
ls1charged's Avatar
he said he didnt have it wide open.
Old 02-16-2006, 03:18 PM
SgtB's Avatar
ok what rpm is your rev limiter set at?
I think you mind need some tuning done to adjust your for rpm-mph settings for shifts
Old 02-16-2006, 03:46 PM
'Trust''s Avatar
Doesnt sound like a tuning issue to me if you were at 3/4 throttle unless your tuning was messed with at anything other than 100% throttle, hitting the rev limiter at 3/4 throttle going into 4th sounds like a clutchpack issue.
Old 02-16-2006, 06:38 PM
i dont remember, speed inc raised it a while back, i want to say 6800, but i think thats wrong
i wouldnt doubt i need the shift points adjusted, ive gone throught 3 different gear sizes and now a 3600 stall
it just seemed odd because i wasnt flooring it
i need some tuning anyways, havent done anything computer related sence before i put the headers on, and im running pig rich right now, used to get like 18mph in town, dropped down to about 15 around town, and the stall puts its about 14.5
Old 02-17-2006, 09:37 AM
SgtB's Avatar
First, I would check your tranny fluid..level, color, and smell..that will set you in the right direction if it is the tranny or if it is a tuning issue.
lmk what you find out
Old 02-17-2006, 11:43 AM
'Trust''s Avatar
Thats the only part that worries me, if it was 100 percent thorttle then not so much. But like the guy above me said, check the condition of the tranny fluid then go from there, good luck!
Old 02-22-2006, 12:25 AM
been meaning to get back to this, fluid is fine if anything at the lower end the the "save zone", cherry red, no burnt smell
have to hit the tollway to get to Tony's dyno day sunday, so ill give it another test run then, otherwise i havent had any problems, but then again i havent been 100+ lately
Old 02-22-2006, 10:37 AM
gettinthere's Avatar
If it's still acting wierd on Sunday I'll take a look at it. I'll have HP Tuners with me.
Old 02-22-2006, 01:59 PM
cool, thanks man
