2 overdrives?
Old 02-14-2006, 11:59 PM
BluLS1's Avatar
Default 2 overdrives?
hey guys, i just bought a 98 z with a rebuilt stock a4 with a 3300 stall. well everything goes good untill i hit overdrive and everything is still good (and i know it's in o/d becuase i can pull it down into d and it will shift down) and after running in o/d a while it acts like it shifts into another gear like a 2nd o/d but doesn't stay like that long and shifts back to the regular o/d. what could this be? o/d not shifting in all the way or what? please help on this.
Old 02-15-2006, 12:03 AM
obZidian's Avatar
hmm...
Ok. lets recap..
your cruising along and you shift into 4th or od, right? Than, soon after the trans will shift again or drop rpms an dfeel less "slippy" or tighter?
That should be your stall locking up if it is a lock-up, which it should be...
Old 02-15-2006, 02:35 AM
BlackHawk T/A's Avatar
TC lockup.
Old 02-15-2006, 10:01 AM
SgtB's Avatar
yes that is your converter locking up.
Old 02-15-2006, 03:21 PM
BluLS1's Avatar
kool kool, but why does it only do it for no more than a mile then comes back out like i gased it and i don't
Old 02-15-2006, 04:32 PM
12secSS's Avatar
You probably have a misfire code causing the TCC to unlock. You need to have it scanned and find out what is causing it to unlock.
Old 02-15-2006, 09:17 PM
BluLS1's Avatar
well my check engine light is on, but i think the guy said that was becuase the drivers side O2 was dead.
