turn signal bulb
Old 02-15-2006, 07:21 AM
SSoofast's Avatar
Default turn signal bulb
Doe's anyone know the bulb number for the rear turn signal lamp?like you could pickup at autozone/advance.2002 camaro ss.
Old 02-16-2006, 10:19 PM
jhug's Avatar
yeah i need this info too heh
Old 02-16-2006, 11:09 PM
waiting2bl33d's Avatar
3157LL is the long life bulb at autozone all your bulbs are going to be a wedge type all dual element bulbs example turn signal and running life = 3157 all single element will be a 3156 hope this helps.
Old 02-17-2006, 08:36 AM
Twister's Avatar
Just so this info is out there....They are 27watt/8watt bulbs. I spent the time looking and so far I find no reason why a 1157 bulb and matching harness will not work for a bad harness.
Old 02-17-2006, 09:27 PM
1157 and 1156 are just older versions of 3157 and 3156 new technology = wedge style your pre 96 automobiles for the most part are 11XX bulbs and 97+ are the 31XX
Old 02-18-2006, 07:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
1157 is what i use. Some places still carry them...or versions of them at least.
Old 02-18-2006, 09:19 AM
Twister's Avatar
Try finding a 3157 harness for less than 25 bucks....that is why I am looking at converting back to 1157. Harness is $6.75 each.
