Y pipe Clearance Issue
Old 02-15-2006, 04:17 PM
KurtRardin's Avatar
Default Y pipe Clearance Issue
I just installed my Pacesetter headers and TSP catted Y. The drivers side of the Y pipe is so low that i cant hardly drive over speed bumps. Its almost a nightmare. Right now i have a borla mouth.
The reason that i got the catted y is because i kinda wanted to keep it quiet. I do a LOT of highway driving and long trips.
I've had the Y pipe off several times to try to adjust it to where it doesnt hang so low but im just not having much luck. Its not the cats that are low its the pipe itself. What do yall suggest?
Are true dual setups pretty high up? Do you have to weld anything with TDs? Is there such a thing as a TD that is quiet (dumped). Do ORYs offer more clearance?
Old 02-15-2006, 04:35 PM
SouthernSilverSpeed's Avatar
maybe you are lucky cause y pipes usually tend to be too high up so they rub the bottom of the car.
I would like to see pics of just how low it sits cause my y pipe (ORY) is very high up (still rubs every now and then) and I still have issues of scraping with some of the larger speed bumps. Also my car is stock height so I think it is just the 3" piping!
Old 02-15-2006, 05:56 PM
KurtRardin's Avatar
My springs are stock too. LS1tech wouldnt let me put the pictures on because they were too big, so i just put them on my cardomain page 2.
Old 02-15-2006, 06:02 PM
00scss's Avatar
You have pretty good clearance compared to my qtps on sportlines
Old 02-15-2006, 06:30 PM
KurtRardin's Avatar
Really? Its only a few inches! Dang it... Do TD setups offer more clearance?
Old 02-15-2006, 06:32 PM
T/AFOSTERWS6's Avatar
just a thought but, dont drive over speed bumps?
Old 02-15-2006, 06:33 PM
sorry. had to. my TSP catted Y sits a little low on the d/s as well, not much else I can do to adjust besides a 30 LB sledge
I have about 6 inches of clearance, and a rubber stop mounted between the pipe and the floor, works fine.
Old 02-15-2006, 08:28 PM
00scss's Avatar
I would say go with a custom y.
Old 02-15-2006, 08:40 PM
KurtRardin's Avatar
custom y as in go to the local shop and have them fab up a pipe that isnt mandrel bent? My shop doesnt have mandrel bent pipes.
Old 02-15-2006, 08:43 PM
00scss's Avatar
Yes, but find a shop that you would trust and can do the mandrel bends. There was a thread a little while back discussing mandrel vs. crush bends.
