Need pictures of back of engine with wiring harness
Ok, so I have a wire in my harness that is wearing through somewhere on the back of the engine. I can't see very well under the cowl (T/A) - so it would be helpful if anyone has a pciture of what the wiring harness should look like.
My wires are way too tight (after heads/cam swap) and one of them has finally rubbed on a bracket long enough to ground out perdiodically and cut all spark. I need to re-route my wiring harness but I am not sure how it should actually look because it has been almost 2 years since the swap.
TIA
TIA
