bronze fork pad feedback
Anyone used the bronze fork pads? Any increased noise, vibe through shifter with these?
I've gone through the plastic ones but I think it was the result of a dragging clutch due to a faulty slave but I figured I'd upgrade to bronze this time. Opinions on this?
I put them in every rebuild. I have been using them since December and no, there should be no noise or they are installed improperly. I will never use the plastic ones on a rebuild unless the customer is on a budget and the pads are not in the budget. You can put them on ever fork for $15.00 each and is cheap insurance. I have seen the plastic waste away in less than 2 months and do not recommend using them.
Joe
T56Rebuilds.com
Joe
T56Rebuilds.com
