help, what kind of batteries are u guys using?
Old 02-16-2006, 04:29 PM
HawaiianZ28Rider's Avatar
Default help, what kind of batteries are u guys using?
ok well i mistakenly blasted the music but i got to clean the inside of my car really good but now it jus died on me, any idea what battery i should use?
Old 02-16-2006, 04:44 PM
eselki's Avatar
I use an Optima red top. I've never had any problems with it.
Old 02-16-2006, 08:10 PM
SmaknaSS's Avatar
I just had my stock battery start leaking acid inside the engine compartment, I switched to a red optima because they are filled with gel and thier not suppost to leak,If thats true I will probably never put a regular battery in any car that I really care about again, If It's the kind of car I know I'm going to get rid of in two to five years(like a daily driver) I'll just replace the battery with the conventional stock replacment kind.BTW the red optima has been working good.
Old 02-16-2006, 08:15 PM
Arachnotron's Avatar
After cleaning all the crap that the stock battery leaked out I replaced it with an optima red top.
Old 02-16-2006, 09:06 PM
67Ranger's Avatar
ive got an optima red top, and it was good until I left it for about 4 or 5 months without charging or anything. Now it cranks a little slow, but still works good.
Old 02-16-2006, 10:16 PM
LS69TA's Avatar
Optima red top. I had it on the '69 and swapped it onto the T/A when I pulled the LS1 out. No problems so far. I'd like to get one for the Dodge as well.
Old 02-16-2006, 11:07 PM
Slammed99s10's Avatar
Had a optima yellowtop in my truck (now sold) for over 4 years, and now running a redtop in my camaro since Aug 05'. Wouldn't switch to any others.
Old 02-17-2006, 12:31 AM
Flaminchiten67's Avatar
Red top in my 67 and its the best battery ive bought, will put one in my SS this summer
Old 02-17-2006, 07:21 AM
LS1Tech Sponsor
Superman09's Avatar
red top
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 02-17-2006, 08:06 AM
Mr Incredible's Avatar
I have been using Douglas batteries with good luck. The battery in my truck and the one in my Camaro each cost in the $50-60 range and have done well for me. They also come with a 5 yr warranty. Check your local battery shops for one that is a distributor of Douglas products. I could buy about three normal batteries for what an Optima would cost. No doubt Optima makes great batteries, but you'll pay a great price for them. The last one I looked at was about $170!
Alternately, I've had good luck with Wal-Mart and with Tractor Supply batteries. The price is right and I've never had a problem with one dieing prematurely, terminal malfunction, or springing a leak.
I wonder if your battery wasn't fastened down properly and it rubbed a hole in it? That's easy to do for a replacement battery that isn't 100% the right size.
*non-sponsor link removed.
Old 02-17-2006, 08:33 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Optima Red Top here.
Old 02-17-2006, 10:06 AM
Silver02TA's Avatar
diehard gold for me
Old 02-17-2006, 10:30 AM
weestro's Avatar
Yellow top. Running strong for over 4 years now. If you've got custom stereo work look into the yellows.
Old 02-17-2006, 05:04 PM
SmaknaSS's Avatar
I was also able to weigh the red optima battery at 33 lbs before I put it in my car, does anyone happen to know how much the stock one weighs just for the hell of it? I would guess about the same.
Old 02-17-2006, 05:24 PM
SSDude's Avatar
Was any fabrication needed to install the Yellow Top?
Old 02-17-2006, 11:07 PM
WILWAXU's Avatar
Optima Red for street use.
Old 02-17-2006, 11:10 PM
67SS&99SS's Avatar
I just bought an optima red top today. My stock style battery decided to take a crap on me this afternoon. I've heard nothing but good things about them, and it matches my red SS too
Old 02-17-2006, 11:12 PM
weestro's Avatar
Yes, I did have to trim the coolant reservoir a bit on the ridge near the neck. No biggie and it fits snuggly. This is the most powerful, most reliable battery I have ever owned (I've had red tops too). And I run a 1000 watt system fwiw...
Old 02-17-2006, 11:13 PM
Retired Street Racer
Matt D's Avatar
13lb Hawker PC680 in mine
Old 02-17-2006, 11:19 PM
Starz T/A 17's Avatar
I just put a Autocraft Silver battery in from advanced, Actually exceeds the factory rating and have not had any problems with it, just cant see spending $100+ for a battery
