Drag Racing Tech - Is there a How to Launch a A4 at the track?
Tri5Nerd
02-17-2006, 11:28 AM
I'm new to racing and want to know. I cannot find anything here about the proper techniques to launch a A4 when at the track. How do you properly burnout, stage and launch?
Let's use my truck as a example:
Stock 2001 Ls1/4l60e
Ported TB
SSF 3500
9" with 3.73 gears
Tires 245x17, 315x17 DR.
How would I go about prepping and getting off the line to run the best possible time I could?
1slowcar
02-17-2006, 12:52 PM
Written by Jeff Tyler
DRAG RACING BASICS: PIT GATE TO FINISH LINE!
1. Contact your local track, and ask if they have a "street night", or
"test and tune". For complete beginners, it is best to avoid bracket
racing events, or any points race. On street night, almost everyone
running is just as new to this as you are! The track officials know
this, and are ready to felp. It is also a much more relaxed atmosphere.
2. If possible, call a few buddies, and go to watch the first time.
Check out the "lay of the land". Ask the racers in the pits how
everything works. Remember, everyone there is a car nut just like
you, AND EVERYONE THERE WAS A "FIRST-TIMER" ONCE
THEMSELVES! Everytime I go, I get asked questions by new guys!
Just make sure you pay the extra couple of bucks to get in on the
"pit side", as it won't do you much good to sit on the spectator side,
which is usually deserted on street nights.
3. When you decide you are ready to give it a try, goto the pit gate,
you will need to inform them that you intend to race. They will
charge you for car & driver, plus extra for any spectator friends you
brought. At the Motorplex in Ennis, they charged $18 for my wife
and I (I raced, she watched) last season. You will be given a tech card.
4. Go find a pit space. Only take up one space, as the night goes on,
it can get very busy. Unload any loose items in your car (I would
suggest you leave what you can at home). Fill out the tech card and
sign it. Usually, they also have a space on the BACK that you must
sign, so look there also. Ask some of the cars parked near you
whether they know if tech inspection is open, and where it is
located (usually at the back, or beginning of the staging lanes).
Its a good time to make new friends, and enjoy looking at all the
great cars!
5. When tech inspection opens (usually 10-15 minutes after the gate
opens) go to the tech area. If you are taking your street car, and it
is not a death trap, you will pass tech. Some obvious things you need:
seatbelts, safe tires (no cord showing), radiator coolant overflow catch
canister (the factory one is fine), no blatant fluid leaks pouring out,
etc! Also, shorts and tank tops are not allowed! YOU MUST WEAR
LONG PANTS WHILE ON THE TRACK! All the officials look for
this, so don't try to sneak it by them. This is about it for a street car.
If your car runs faster than 11.99, then the entire game changes.
However, if youre running that well, I'll bet you've been to the track
at least a time or two....The tech inspector will write your cars number
on the window where it is visible by the timing tower. If staging lanes
are not open, then return to your pit.
6. The track announcer will come over the PA system, and say that
the staging lanes are open. Listen carefully, as some of the larger
tracks have many lanes (The Motorplex has 10), and they may
have cars of differant speeds report to differant lanes. On Friday
street nights at Ennis, they just say lanes are open, and everyone
just forms two lines. When they have a TON of cars, they split
up the lanes by estimated ET of the car. Take your best guess,
as this is not crucial. For your first run, I would suggest you get
in line with the 15 second cars if you honestly have NO IDEA,
as that is a good middle ground. The staging lanes go slowly,
then quickly, so STAY WITH YOUR CAR. DO NOT RUN
YOUR AIR CONDITIONER! The condensation on the system
will drip down onto the track. BELIEVE ME, they look for this,
and if they see something dripping, then will pull you off the
starting line. When they check the liquid on the ground, and see
it is plain water, they will chew your butt, and send you to the
back of the staging lane.
7. At the end of the staging lanes, there SHOULD be a track official.
Watch carefully, and when it is time, he will point at you, and then
point where he wants you to go. His job is to pair up cars to race,
then put them into correct lanes. The idea is to keep you from racing a
9 second alcohol Camaro. By the way, most tracks make a strong
effort to keep near stock street cars from running sub-10 second
race cars, and will usually hold a street car, and let the race car make
a solo run. Unfortunatly, they don't always do this...If you find
yourself lined up next to a John Force replica funny car, feel free
(I advise beginners to do this!)to just sit there for a moment when
the light goes green. Let the race car roar away from the starting line,
then a moment later, you can go. Who cares that you got a lousy
"reaction time"? Your ET slip will be UNEFFECTED! The timers
don't start until you leave the starting line! This way, if the race car
breaks an axle on a 7,000 rpm launch, and vears into your lane, you
wont be there! I saw a sub-10 second car with an incorrectly set up
rear suspention vear so hard at launch that he almost took out the
starting line tree....
8. Just before you enter the water box, there should be another track
official. He will make sure that your seat belt is on, all windows are
rolled up, and will hold you until it is time for you to do your
burnout. Do not enter the waterbox until instructed. If it is near
sundown, turn on your parking lights. This is a required RULE at all
tracks. This is how the officials can see where you are on the track,
so they don't send another pair of cars while you are broke down at
the other end, ON THE TRACK!
9. Since this is for beginners, I will assume you are on street tires.
DO NOT DRIVE THROUGH THE WATERBOX! Your treaded
tires will just pick up water in the treads, and when you do your
burnout, it will sling water all over inside the wheel well. You will
then track the water all the way down the track, and water will be
dripping down onto your rear tires, making them VERY slick!
If you do this, you make the track dangerous for everyone, and
you may be asked to leave if you do it again. The water is for slicks,
not treaded tires. DRIVE AROUND THE WATERBOX, then get
your car centered in the lane. Back up slightly if needed. For street
tires, I 'personally' do not think that a burnout does much at all.
Street compounds are hard, and high performance tires are
specifically designed to not heat up. Heat causes high speed tire
failure, that is why you paid big bucks for "Z" speed rated tires. Now
your trying to heat them up??? If I run my street tires, I do a quick,
short burnout to clean the tires off.
10. Do not pull up to the tree! Every beginner does this. The staging
beams are actually about 15 feet or so BEFORE the tree! Hopefully,
you took my advise and watched the other cars run first, and looked
to get an idea where everyone else was pulling up to. If you cant
figure it out, don't worry, the starter knows it is "street night", and
will felp you. When he realises you cant find the staging beams,
watch him. He will walk up next to your car, and motion to you to
either pull up, or back. Again, don't get embarrassed, or upset.
The starter has to do that probably 20-30 times a night. SLOWLY
pull forward until you see the very top, small yellow light come on.
You are now "PRE-STAGED". It is considered a racers courtesy
to wait for the other car to prestage, before staging. Then gently roll
forward a few more inches, and the other small yellow light right
under the top one will come on. You are now "STAGED". Do not
roll forward too far, or the "PRESTAGED" light will go out, and
you may be required to pull back, to relight that light. That is called
"deep staging", and is usually not allowed on street nights. There
-should- be a blue light turned on, on the tree, which notifies all
racers that "deep staging" is not allowed. If you do accidently pull
forward too far, and deep stage, DO NOT PULL BACK UNTIL
INSTRUCTED TO DO SO BY THE STARTER. He may just
start the tree anyway, and you would be sitting there in reverse!
Now, watch that very bottom, large yellow light!
11. The starter will activate the tree, and the yellow lights will come
on, one at a time .5 seconds apart. When the last yellow light comes
on, GO! By the time you react, then your car reacts, the green light
will be on. Trust me. If you red light, it is no big deal. Afterward,
check your reaction time, and adjust. .500 is a perfect light on a
standard tree (The pros use a tree where all the yellows come on at
once, then green. A perfect light on a pro tree is .400).
12. If you only take one piece of advice from me, please let it be
this: DON'T TRY TO SET A NATIONAL RECORD ON YOUR
FIRST RUN! If this is your first time at the track, PLEASE make at
least one pass where you are only running at 80%. This will give you
a chance to see what the track feels like, what your car feels like,
where the finish line is exactly, where the turn off is exactly. Your
senses get overwhelmed when trying something like this the first
time. A mistake you would have caught easily any other time can
cause you to wreck your car. I've seen excellent drivers wreck great
cars from a simple mistake that would have never caught them
otherwise. It can happen to you too. This is the most fun you can have
with your clothes on, but it is serious stuff too. Treat it that way. Stay
in your lane at all costs.
13. Make sure you know exactly where the finish line is! Most new
racers brake WAY too early...the speed trap beams are located 66'
BEFORE the finish line beams. Make sure you are not mistaking the
speed trap for the finish line!
__________________
chaman
02-17-2006, 01:05 PM
Good reading!! But where the hell is the A4 launching technique??????
1slowcar
02-17-2006, 01:30 PM
lol brake-gas ....... GAS :drive:
Tri5Nerd
^^^ What he said, I've read this article and even book marked it but it does not explain how to launch the a4.
Thanks
1slowcar
02-17-2006, 01:36 PM
turn stage light on
hold brake and gas just above idle
let go of brake
mash gas pedal
mvonada
02-18-2006, 09:30 AM
Move to line until the 2nd stage light comes on, you are staged, with your foot on the brake move the gear shift to neutral and gun the engine , you will feel the brake pedal go down alittle(this little trick makes the brakes grab much better), shift back into drive and bring your rpms up to 1800-2000 (rpm should be up to just before your tires start to spin), then 3rd amber light and push the pedal under your right foot through the firewall and let off the brake at the sametime. This little method, push gas-off brake at the sametime will take a little practice. So go out and have some fun, it will all come together with practice and by the way you can practice this system off the track as well.
Good luck!
camaronut502
02-18-2006, 12:05 PM
i had my 3400 stall and now with my 4000 you oculdnt just nail off the line.. (im on nitto dr's). i would hold the brake an bring the rpms up to around 2800 and when i see the 3rd yellow i roll into the throttle at a moderate pace(takes some practice) best 60' is a 1.61... everytime i have tried to nail it on green i get nothing but tire spin and 2.xx+ 60's.... oh also if you run a nitto dr make sure you get them really hot, i normally do it in 2nd so the car will shift and get the speed up and once i see smoke in both mirrors i'll count to 10 then walk it out a little.
--Matt
1slowcar
02-20-2006, 12:18 PM
--Matt
I had a 4500 stall .. I couldn't leave at more than 3100-3200 on the brake :eek2: .. It would leave in 2nd gear and only did this when you stalled it more than 3100 ... but leaving at high rpm vs idle was worth about .10 in 60ft
BubaGumpShrimp
02-20-2006, 10:48 PM
1slowcar, if you brake stall it past 3,100 and it leaves in 2nd you have false misfires due to the converter, you need the misfires tuned out and you will be able to leave the line higher then 3,100 rpm...
1slowcar
02-21-2006, 06:28 AM
hmmm .. I didn't know what caused it .. that will come in handy on the next car I build .. thanks man !
Tri5Nerd
02-21-2006, 03:08 PM
Thanks guys for providing the necessary info to launch.
I'll try to get a feel for this in the next few days.
I know it may seem like a silly question but it best to ask a silly question than to screw something up. :)
