Delteq-Opti Direct LT1 opti spark replacement
Just wanted some feedback on the Delteq opti spark distributorless replacement for the lt1 if any one has one tell me youre thoughts
No issues. You may have to replace the optical portion of your opti cuz it might be giving the system a bad cam signal. I had the problem but once that was solved, it ran tight. Only problem I see is timing advance control for nitrous use. I implemented an MSD DIS-4 system to solve that problem but it's more $$.
1994, 94, conversion, delteq, direct, lt1, lt1opti, opti, optidirect, optispark, replacement, replacment, spark, system, z28
