General Maintenance & Repairs - Turn signal relay?
zwhid
02-18-2006, 11:45 AM
If the turn signal lights on my dash dont work and my turn signals dont work is that the relay? the hazard lights work and the lights go on when i use the keyless entry.
Bill's 02 Z-28 SS
02-18-2006, 12:45 PM
Hi
First, we need to know if it is both side that don't work. If it is both sides then I believe the relay is cause, if it is only side check the bulbs. Put the directional on and look to see which light is not working.
Bill :usa:
zwhid
02-18-2006, 03:33 PM
yeah both the dash lights dont work. the bulbs look like they are working when i turn the hazards on
ProjectDuStU
02-18-2006, 05:03 PM
ive got this same problem please help!!!
Syxx613
02-18-2006, 07:33 PM
here is ur answer....
your turn signals are dual filament bulbs. your hazards and turn signals are not on the same circuit and do not use the same flasher unit. if your turn signals dont even come up on the dash, then just go get a new turn signal flasher unit, it is ur problem. its under 5 bux so no big deal. im not sure where its located exactly, but im pretty sure its on the drivers side under the kick panel. hope this helps! :)
zwhid
02-19-2006, 03:31 PM
thank you Syxx613, that solved the problem
scorched_ss
03-23-2006, 12:26 PM
My bulbs flicker when i turn on the directionals in both directions - could that be the same problem?
If so does anybody have the part number on the turn signal flasher unit?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
