Header install Question
I'm installing the pacesetter LT, I got the driverside manifold out and all the the passenger bolts out, the problem I have now is the dipstick is routed through the manifold, how do I remove the dipstick? I took the 15mm bolt out that mounted it to the engine block already. do I just pull on the dip stick to get it out?
