how loud are td's out the back?
Old 02-18-2006, 05:49 PM
jwhert's Avatar
Default how loud are td's out the back?
y pipe and cutout or trueduals out the back?
im leaning towards the ypipe because it wont be loud all the time and i travel a lot, but ive never heard td's out the back, only dumped
how loud would they be(inside the car) out the back on the interstate at 75 w/ the windows up
Old 02-18-2006, 05:53 PM
Full-Force's Avatar
Not bad at all. Depends on the muffler you use. I have extension pipes that I can bolt up to my duals to take it out the back and it quietens it down alot. Assuming the same muffler(s) is used it should be about the same as a y pipe and catback inside the car.
Old 02-18-2006, 10:04 PM
DWillTA's Avatar
They are as loud as any old school true dual setup. This is real dependent on muffler and also if an aftermarket cam is installed. I run Magnaflow round body's and the sound level increased after the cam was installed. I think the sound and performance makes up for any compromises made.
Dave
Old 02-18-2006, 11:37 PM
Element's Avatar
I had to have pipes welded up to my dumped duals to pass inspection (damned things got cut off as soon as it passed, though) and it REALLY quieted things down. It was really quiet cruising and with light to mid acceleration. It DID sound like an old-*** Chevy truck with generic straightpipes, and I've yet to hear a single out-the-rear dual setup I like, but it's quiet, until you go WOT.
Old 02-18-2006, 11:39 PM
67SS&99SS's Avatar
They are a lot quieter than dumps. I've had both. Like the other two posts said, it really depends on the muffler you use. I missed the dumped sound, so friday I had 3 bolt flanges put on the ends of my mufflers so i could go back to dumps whenever I wanted.
Old 02-18-2006, 11:45 PM
blkZ28spt's Avatar
If you have a stock or mild cam, decent mufflers and the pipes exit out the back you should be able to live with duals, even on long interstate or highway trips.
Old 02-19-2006, 01:09 AM
edwardswb's Avatar
mine sounds like a dream from idle to cruising to WOT. setup in sig
Old 02-19-2006, 01:33 AM
That's what she said...
TheBlurLS1's Avatar
Link in my sig to the pictures, videos, and review of my system. I went from dumps to out the back and love them. It's a little louder than a y-pipe setup, but it's only because i have the bullets.
Old 02-19-2006, 04:56 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
they are really loud out the back as well.
