shifting at high rpms
Old 02-18-2006, 08:38 PM
spraynpray's Avatar
Question shifting at high rpms
when i shift when i race (above 5500 rpms it takes a second to go into second and then it takes a second to go into third... is it my throw out bearing and slave because i didn't replace it when i put my centerforce in. but it shifts fine at normal driving speeds
Old 02-18-2006, 11:11 PM
FigsZ28's Avatar
sounds like your hydrolics, do you have the updated slave "288" could also be air in the hydrolic system
Old 02-18-2006, 11:49 PM
screaminbird's Avatar
I just had my CF put in and if you do have the new slave in also I will guarantee you probably still have air in there some where that has to be bled out. I had the exact same problem they had to bleed it like 10 times. Now its never shifted better even at 5500+. Also i dont know how long youve had it in but the pedal feel as well as the egagement point gets alot better after the first 5-800 miles (its a centerforce thing)
Old 02-19-2006, 09:36 AM
SmokinHot98's Avatar
I m getting my CF DF put in next week but when I first got my car it shifted just PERFECT not sure how old my clutch is or if its the stock slave but in nNOV '05 I started getting that problem except mine woulkd start around 4500rpm but that will be in the past hopefully next week
Old 02-19-2006, 11:53 AM
MY99TAWS6's Avatar
Do the master cylinder to slave line drill mod.Its a pain to do with master and slave in the car but such is life.Its usually the reason you can't shift a high rpm.
