Need Help Started Car For First Time
Need help started car for the first time today and a hand full of plastic shavings came out from under bell housing also lost all hydraulic fluid
the pedal feels really funny like its not hooked up at all
New textralia clutch, flywheel and slave cylinder. ???????????
your slave is wiped out. nothing is left. that is the only explanation for plastic shavings and "funny" feeling clutch pedal.
time to take that trans back out.
are you 100.0000% sure you tightened those 2 10mm bolts holding the slave to the trans?
