Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Any idea why my 2 ton floor jack isnt working???
Old 02-19-2006, 03:51 PM
nokeman's Avatar
Default Any idea why my 2 ton floor jack isnt working???
I just got it from some ebay place and, surprise surprise...it doesnt work. When I push the handle down, the arm does not raise. It has oil in it and everything. The damn thing just doesnt want to lift for me! Any help? Thanks!!
Old 02-19-2006, 06:43 PM
BigDaddyZ28's Avatar
It may have a bunch of air in it from shipping. Have you tried bleeding it yet?
Many jacks say to bleed them before first use...
Let us know,
Old 02-19-2006, 06:45 PM
nokeman's Avatar
well I unscrewed the little valve plug and pumped it six times but all that did was pump oil out. The handle moves up and down but it doesnt move the arm. The spring doesnt move or anything. It doesnt make any sense.
Old 02-19-2006, 07:49 PM
firefighter's Avatar
I had that happen once and it was some metal shavings stuck in the valve it wouldn't seat.
Old 02-20-2006, 08:05 AM
nokeman's Avatar
Damn...so its something I cant really fix. I need a new one.
Old 02-20-2006, 08:59 AM
Camaroholic's Avatar
And it'll probably cost more to ship it back than it's worth...
I'd probably take it apart and see if I could clean the surfaces and make sure the O-rings aren't torn, especially if it's a brand new jack. It'd be worth your time to do so.
I run 2 jacks at home. The little guy:
http://www.torinjacks.com/ProductDet...px?ProductId=6
and the big daddy:
http://www.torinjacks.com/ProductDet...x?ProductId=49
That big one weighs every bit of its 107.x lbs. But it'll put my Suburban in the air.
Old 02-20-2006, 02:59 PM
robertbartsch's Avatar
I have a Sears 1.5 ton floor jack that has sucked since I bought it a few years back.....
I've tried to bleed it, refilll it with different fluid, etc. It just won't pump up....
Was your jack filled with non-hydroloc fluid (motor oil, perhaps)? Send it back to the E-bay seller and request a refund.
Old 02-20-2006, 03:56 PM
RHall8612's Avatar
Our original Sears jack is a 30 year relic. Leaks a little bit of pressure, but will still give you plenty of time to get a set of stands under a car. My dad refuses to let it go.
Just picked up a new aluminum jack from Sears for all of like 80 bucks. Works great.
-Russell
Old 02-20-2006, 09:08 PM
Moderator
jimmyblue's Avatar
Some jacks, you have to turn the handle to open/
close the valve, without the valve closed there will
be no pressure built (oil just circulates). Others, there
is a separate valve that has to be closed (like cheapo
ones, you use the end of the 2-piece take-apart handle
as a key).
Or it could be messed up, but you didn't say anything
about closing the valve....
Old 02-21-2006, 09:21 PM
cantdrv65's Avatar
Post
Jimmy if he didnt close the valve.... well I HIGHLY doubt hes that retarded.
Old 02-21-2006, 09:23 PM
cantdrv65's Avatar
Post
and the big daddy:
Ive got a two small sears jacks that look just like you "little guy" except black. They work great for getting the vette completely up on 4 jackstands...
Quick Reply: Any idea why my 2 ton floor jack isnt working???
