Which B.O.V. for high power
Old 02-19-2006, 06:24 PM
GTFORMULA's Avatar
Default Which B.O.V. for high power
I am piecing together my kit and was wondering which bov you high power guys are using. I am leaning towards the turbonetics RAPTOR or the GODZILLA. I am planing on eventually in about a year building the motor and making 1000 horse .I am not looking for something you would hear a little whistle from,I want on that sounds like a real race car. Car info in sig but thats all going to eventually change.l
Old 02-19-2006, 06:27 PM
Turbo2.4Liter's Avatar
tial 50mm
Old 02-19-2006, 06:49 PM
NA$TY-TA's Avatar
On my setup im using the ATI Raceready..... same one the Ohio Boys are running....
Old 02-19-2006, 07:04 PM
GTFORMULA's Avatar
Ive never herd of the ATI race ready .where can I see one, and buy one if it looks like something I would like
Old 02-19-2006, 08:04 PM
kwman's Avatar
With all the experience I've had in turbos and such I've found the Tial 50mm to be the best so far.
I've gone through the HKS SSQV, Greddy Type S and type RS, TurboXS RFL (shitty), HKS type 2, APS dual vent (that one is a damn good piece), Turbonetics, and Tial.
The APS is a great BOV, but the tial seems to be the champ for higher boost applications.
Old 02-19-2006, 08:12 PM
LS1Tech Sponsor
Slowhawk's Avatar
2 TIAL 50mm's on PurEvl's car. 1 didn't blow off enough under higher boost levels and kept blowing off the discharge tube.
Old 02-19-2006, 08:22 PM
Boostaholic's Avatar
Tial 50 here
Old 02-19-2006, 09:25 PM
pwrtrip75's Avatar
can you change the spring in the tial 50mm?
Old 02-19-2006, 10:12 PM
yes you can, they have 7, 9, 11, and 20lbs springs for them
Old 02-20-2006, 07:27 AM
GTFORMULA's Avatar
This is something I just dont understand. Why would you need to adjust the PSI in the BOV? I thought that as long as its under boost it should stay closed. Then when the throttle closed and created vacuum it would open and release any pressure thats in the system. Doent the wastegate control PSI?
Old 02-20-2006, 10:53 AM
the different springs are for engines pulling different amounts of vacuum
Old 02-21-2006, 06:59 AM
GTFORMULA's Avatar
Anyone else know why you would need a certain pound spring for vacuum when vacuum is rated different.
Old 02-21-2006, 08:44 AM
MY99TAWS6's Avatar
Cars will be various amounts of vacuum when you back off the throttle.
A normal car is around 18 to 20 range or so and then you add cams and stuff your vacuum drops sometimes a lot so that would be why I guess.Most blow offs don't have springs they must adjust to a point but some of the blowoffs have problems with higher boost levels.
I think just about any bv would be fine for 5 to 12psi or so mabye 15psi.On cars like my talon guys running like 30psi can have problems with cheaper ones.
The tial are very good and are used on most serious turbo builds.I bought an hks ssv which would likely be fine for lower boost applications but am selling it and getting a tial since going high boost in my 97 talon.The tials are not too expensive really either.
The do vent to atmosphere so would think they are reasonably loud.If you want super loud there are ones like the turbo xs rfl..nicknamed real f##king loud..!
Some may thing loud blowoffs are ricey but to me they are just a cool turbo sound effect.I like them.
Old 02-21-2006, 08:45 AM
MY99TAWS6's Avatar
Actuall was a bit mistaken there,most blowoffs do seem to have some adjustments on them.Guess the tials are just more precise with the swappable springs.
Old 02-21-2006, 11:34 AM
kwman's Avatar
^Some do, some don't. The SSQV and the like are pull type BOVs and don't have springs. They claim they don't leak, but the truth be told they leak but there isn't anyway to fix the problem. Yeah the Tials are usually just a better piece, plain and simple. I don't like the sound of VTA but the Tial sounds pretty gnar.
Old 02-21-2006, 05:10 PM
GTFORMULA's Avatar
I kind of see now ,so if my car pulles 10 inches of vacuum when the throttle closes for example I would need a softer than 10 pound spring.Is that right?
Old 05-05-2006, 03:34 PM
kwman's Avatar
^Sorry its taken me so long to respond GTFormula, you want to have your BOV spring adjusted to within 2 psi + or - of what vacuum your car pulls at idle.
Old 05-05-2006, 04:07 PM
bboyferal's Avatar
HOLY Cow! It's amazing you remembered at all!
Old 05-05-2006, 05:40 PM
NA$TY-TA's Avatar
Sorry about the late reply.....
Its working fine for me and the Ohio Boys....
Left hand side....
Far left here also...
ATI rates it at 2300HP and its a lil spendy at about $360
Kyle
Old 05-05-2006, 05:43 PM
frcefed98's Avatar
Gonna have to sell my TiAL and go for the ATI race ready...or another MONDO!!!!
Damn TiAL is too quiet
Quick Reply: Which B.O.V. for high power
