TR55s car run like crap feels down on power
Old 02-21-2006, 06:51 PM
SSPerformance's Avatar
Default TR55s car run like crap feels down on power
After the header install on my brothers z i installed tr55 gaped at .050 installed new msd wires. When your drive the car normal its fine. when u floor it from a roll or a dead stop the car hesitates.... im lost gona thro a set of AC delcos in and see what happens?
Old 02-21-2006, 06:55 PM
Redneck Z's Avatar
Originally Posted by 1984camaroz28
After the header install on my brothers z i installed tr55 gaped at .050 installed new msd wires. When your drive the car normal its fine. when u floor it from a roll or a dead stop the car breaks up.... im lost gona thro a set of AC delcos in and see what happens?
Don't be so quick to ditch the TR55's. They are an excellent plug! I'm sure your issues are somewhere else. Maybe you cracked a plug, plug wire not on all the way, etc. etc.
Old 02-21-2006, 07:00 PM
ss rally red's Avatar
My guess is the headers have caused a slightly lean condition and the incorrect AF ratio is the problem,if you cracked the porcelin of one of the plugs you would see a misfire code, a tune would definetly help but in the meantime just give it a couple hundred miles of normal driving to get the LT trims in line and see how she does.
Old 02-21-2006, 07:04 PM
kenp's Avatar
I tried the TR55's and wasn't impressed. Car came with Denso plugs. Went with Denso Irridium. Car runs great.
Old 02-21-2006, 07:11 PM
Looking at your sig I see no headers,or NOS which is why most peeps use the TR's. A lot of us that have both swear by the TR's.
Old 02-21-2006, 07:12 PM
Redneck Z's Avatar
Tr55's N/A and TR6's N20.
Old 02-21-2006, 07:14 PM
black00TA's Avatar
when i switched to the TR55's at first i almost thought i lost power. but still had original wires. so i went with the msd wires and now its great. i noticed bigger dif going to the msd wires over the tr55's
i was skeptical at first, but ill use TR55's or the TR6 later on..over anything else hands down
Old 02-21-2006, 07:22 PM
did the plugs after the header where on they are not cracked the plug wires are all on i cover all the bascis. i just threw the scanner on it when u got to WOT the car is missen at the #1 and #8 cyl
Old 02-21-2006, 07:23 PM
after doing headers on my buddys 98 ta same setup never had a problem
Old 02-21-2006, 07:24 PM
ls1muscle's Avatar
I think your having problems elsewhere if your having problems with NGK-TR55's. I have them, along with stock plug wires and the car runs great.
Old 02-21-2006, 07:25 PM
black00TA's Avatar
it wont hurt to give it another look over, i agree with redneck. your problem more than likely lies in a connection. may try pulling each wire off and reinstalling all together.
Old 02-21-2006, 07:26 PM
why whould it only be doing it under load
Old 02-21-2006, 07:35 PM
Redneck Z's Avatar
Rather than scrap the TR55's all together, I'd replace the #1 and #8 plugs and test and replace, if necessary, the accompanying wires.
Old 02-21-2006, 07:46 PM
that what i thing i will do.......... replace thoes 2 plugs and see what happens.... who no's what meat head droped the box at napa
Old 02-22-2006, 09:49 PM
cowboysfan's Avatar
some questions are asked and answered and this is what "we" get !!!!!!!!!!!
fuerzaws6
Old 02-22-2006, 11:04 PM
WILWAXU's Avatar
fuerzaws6
I agree.
Old 02-22-2006, 11:05 PM
WILWAXU's Avatar
**Personal Flame wars will not be tolerated here. If you do not have anything technical to add to the discussion I suggest you move on.**
Old 02-23-2006, 03:09 PM
replaced them and still feals down but hes runing 89 whould that have any effect
Old 02-23-2006, 04:00 PM
FUN LS1's Avatar
Yeah, when I put the TR55 IX's in I used Taylor Spiro Pros to replace the stock wires. Threw on some 100% Silicone heat shields too, but with coated LT's, it's actually cooler under the hood than it was with the stock exhaust.
Old 02-23-2006, 04:02 PM
FUN LS1's Avatar
Dang, he's cheating himself out of a lot of power, and risking detonation. I run 93, often with octane boost.
