General Maintenance & Repairs - these squeeks are driving me insane
chrisryn64
02-21-2006, 11:03 PM
It's true what they say, these cars are awesome but good lord do they have sqeeks from every part.
My biggest headache is coming from my belts. I changed belts about 4 weeks ago. This didn't stop the constant squeek. I figured it was probably the idler pulley so I replaced this last saturday and thankfully the sqeek stopped....for all of 2 days. It started back up today. Seems it is only making the sound at low rpms, it goes away when I'm driving and seems to also go away at idle after the car has been driven for a few miles. Any ideas? Could it be tensioner pulley?
Thanks
waterbug1999
02-21-2006, 11:12 PM
Get some of that "anti-squeak" crap from the auto store. Or you can always squirt some dish soap on there.
Renegade
02-21-2006, 11:13 PM
For the most part it's just something you have to deal with. But Subframe Connectors tend to stiffen thigns up, and reduce all the little squeaks and rattles. Overall, I would rather deal with my cars problems and have an F-Body, than drive a Mustang or something lol.
chrisryn64
02-21-2006, 11:15 PM
I was skeptical if that would work, do I just spray it on the belt or in the pulleys?
don't get me wrong, I love my f-body and it's awesome with reliability, just the little things that drive me crazy lol
waterbug1999
02-21-2006, 11:30 PM
To be honest, I have never used the "anti-squeak" crap from the auto store. I would imagine that you would just spray it on the inside of the belt.
I used dish soap.
Just rub some on the belt. You know you got 2 belts (one for AC/one for all others) so, start with one and see if it goes away. If not, then do the other.
chrisryn64
02-21-2006, 11:37 PM
I'll try it with some soap tomorrow. I rub it on the inside on the belt, the part that's touching the pulleys?
waterbug1999
02-21-2006, 11:43 PM
Yeppers.. Just rub some soap on the inside of the belt (where the grooves are). Just dont cake it with soap as it will end up all of the inside of your hood. (its soap so you might clean it while taking it off.. lol)
Thats what I was told to use and it fixed my squeaking problem. Just dont use grease or anything along that lines as it might cause the belt to slip. Told me soap would work fine as it woulnt dry out the belt either.. Cood luck.
djsanchez2
02-22-2006, 12:23 AM
don't use the belt conditioner...total crap. i'd give the soap a try though.
formula8r
02-23-2006, 07:51 PM
if you have already replaced BOTH belts, then id go straight for the pullies, u said you already replaced the idler, hit the lower and upper tensioner pulleys next, check every pully using a stethescope or long ass screwdriver holding it from the pully center to your ear, youll know right away which one it is, anyone of the bearings inside couldve gone bad
KillerKlown
02-24-2006, 10:34 PM
don't use the "no sqeak" stuff, it says on the can not to be used w/poly belts like we have. check your a/c pully, the bearings might be shot. turn on the a/c at idle and see if there is a difference. thats what happened to mine. it was quiet when cold, but once warmed up it sqeaked like mad at idle. as far as squeaks go, my t-top on the drivers side makes a lot of noise! although reluctant to "lube" it as i do not want the top to fly off on the freeway as they tend to have a rep for doing that on their own! :eyes:
turbols1_05
02-25-2006, 12:52 AM
its the tensioner mine is doing the same thing at low rpm it happens when u start modding ur car, the pulley can't keep up/ I would up grade to a performance tensioner so u don't have to worry about it again.
