TB porting...What is good to use to fill in holes?
What is good to use to fill in the stockholes on the TB? Any kind of epoxy, JB Weld? What are most peo. using? I dont want something that will come apart or that I have to get from NASA either. Thanks
Moderator
I used J-B Weld but did it in three layers baking it after
each overnight in the oven. I used aluminum foil to make
"dams" in the ports and the first coat was just a seal &
tooth coat.
tooth coat.
