b1er
02-22-2006, 10:11 AM
If I connect a DVOM to the #10/white wire, what should the reading be on the meter?....
as of now I have a window switch for my NOS 5177 kit wired properly but the switch does not activate....the trouble shooting guide says the switch is not receiving an ignition signal....everything else is working normally....I can by-pass the switch and the 'noids and realys all work like they should...
the switch is an e-bay special Baker electronics adjustable switch....
I put my meter on the #10 wire and the only voltage it shows is .100 volts dc and it falls to .035 as the engine is revved....I tried using max/min on the meter to see if it was outputing the 5v @ 2 pulses per revolution....didn't work....so I don't know if I should blame the wiring or the PCM signal or the switch itself.... :confused:
