Stock Auto Trans Cooler?? Never seen one...
I though the power steering cooler was the metal section in the upper radiator hose that has the tubes going to the power steering. It is round in shape, looks nothing like that.
I have never seen a tranny cooler on an fbody from the factory. I have an 00' formula and the only optional cooler was for the power steering and is the tube like the one described above.
cooler
Hey Guy's
I'm the one that won that auction. I'll let you know wht it is when I get it.
I,m doing a M6 - 700R4 HD swap. Lazy do not want to shift all the time. Build these trans all the time. With the right parts they are strong. Do need info, part numbers for speedo parts.
2001 Z28
Red
M6 soon 700R4 HD
Touque Arm, Banzai Enterprises
HD Racing Motor Bay/Firewall Brace, Banzai Enterprises
Rear Shock/Spring upper Brace, Banzai Enterprises
2 1/2 Stainless Y pipe into a 3" Merge pipe, stock cats outlet removed and
inlarged to 2 1/2
Magna Flow exhaust (LOVE IT) Front of inter. pipe was inlarged to 3", not
2 3/4
3.73 gears
Power Coated calipers and rotors (just hub part)
Power slot rotors
PFC pads
Valvoline, syn fluid
Amsoil in trans, motor, p/s
Mecca fluid in cooling system
thermostat modified to open 180 deg
Computer,
Hurst shifter with shortened chrome handle
ZO6 wheels
275/35-18 295/35-18
Suspenshion tech springs
Suspenshion tech sway bars
All poly bushings, front end, rear end
Lakewood rear lower arms
Rear lower arm relocating brackets, (look like stock) Banzai Enterprises
adj. track bar with Hiems (no noise) Banzai Enterprises
KYB shocks
26 MPG
1996 Z28, Drag Car, Super Gas, Super Comp
Black, will be repainted Off White, Orange, Yellow
383 SBC, Banzai Enterprises
Powerglide, Banzai Enterprises
8" TCI
Full Tube Chassis, Banzai Enterprises
4 Link
9" Ford
Strange Struts
Being built as I type
If anybody has numbers for speedo parts let me know
Banzai
banzaient@bellsouth.net
2001 Z28
Red
M6 soon 700R4 HD
inlarged to 2 1/2
2 3/4
3.73 gears
Power slot rotors
PFC pads
Computer,
ZO6 wheels
275/35-18 295/35-18
KYB shocks
26 MPG
8" TCI
4 Link
9" Ford
Strange Struts
Banzai
