y pipe bangin curious ??
Old 02-22-2006, 09:44 PM
Charlie@LsXperts's Avatar
Default y pipe bangin curious ??
i have read about the y-pipe banging when you do headers, how annoying/bad is it is it really that bad?? anyone know of a makeshift way to fix this. i was thinkin of havin my exhaust man weld a bar from the pipe to the body but it may break? flex pipe at collector? mufflex hanger really work?
Old 02-22-2006, 09:47 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Usually there is no banging...if there is you just got to go in and adjust it basically.
Old 02-22-2006, 09:48 PM
waterbug1999's Avatar
Mine was banging under the seat/knee area. I had a local shop guy get a 6" - 8" hose and pop rivet it to the floor board. So, the exhaust could move freely and not bang on the metal floor board. Worked like a champ!
Old 02-22-2006, 09:52 PM
273sunsetZ's Avatar
I just got some installed and the y does bang the floor. I'm going to go to an exhaust shop and get them to bend the pipe to fit the dip in the floorboard. Thats what everyone tells me to do. It worked for them.
Old 02-22-2006, 11:18 PM
ChaseSS's Avatar
poly motor mounts are supposed to work as well
Old 02-22-2006, 11:21 PM
MM98's Avatar
Poly motor mounts cured mine... I think if you tried to weld a support bar from the y-pipe to the body, you would get alot of vibration from the pipe.
Mike
Old 02-23-2006, 11:39 AM
WhiteRhino's Avatar
I say poly mounts cant be beat as well.For $50 and a day of your time working on your car!
Old 02-23-2006, 12:07 PM
SIC LSX's Avatar
ive seen a poly trans mount fix the problem
Old 02-23-2006, 05:27 PM
Juiced2000SS's Avatar
Bangs pretty good, used the Mufflex hanger works great.
Old 02-24-2006, 02:28 PM
SLO98Z's Avatar
Take a 4" angle grinder and cut out the part of the floorpan that's in your way. It took me a little while to get it right, but my pipe now has good clearance. My Kooks setup tucks way too well.
Old 02-24-2006, 03:27 PM
Luna's Avatar
I just put the mufflex hanger on my car and it didnt work, I am going to try to loosen the header up a bit and put something in between the floor and y and keep the mufflex hanger that way it wont bump and any vibrations should be minimal
Old 02-24-2006, 03:55 PM
Chas1's Avatar
Mine have never banged.
Old 02-24-2006, 04:50 PM
shawn's SS's Avatar
How about a pic of your ground clearance?
Old 02-25-2006, 01:21 PM
wicked z28's Avatar
It Should Not Bang If It Does It Was Not Installed Right,it Just Needs To Be Heated Up And Bent Into Place.
Old 02-25-2006, 01:49 PM
black_z's Avatar
Im going to weld a valvespring between the ypipe and floor, or crossmember. My pacesetter y banged horribly, a poly tranny mount and some radiator hose helped, but its not gone.
Old 02-25-2006, 11:15 PM
99blancoSS's Avatar
How is a poly tranny mount supposed to stop the engine from rocking? The real problem here are the soft rubber factory motor mounts. Replace the drivers side and your done with it. I've been this route. Take it to an exaust shop and get underneath and look for the tights spots and adjust accordingly but you'll need to swap motor mounts to stop the banging. Anything else is just a bandaid and isnt solving the problem. Welding valve spring?!? wtf, Please fix it right.
Old 02-26-2006, 11:45 AM
black_z's Avatar
A valvespring will work just fine until I switch to true duals.
