bad night last night
Old 02-23-2006, 09:22 AM
LS198Z28's Avatar
Default bad night last night
ok i changed the valvesprings out on the Z and put it all back together and one of my rocker arm bolts stripped out. what are my options that i can do. is helicoil an option and what size helicoil should i use?
Old 02-23-2006, 09:52 AM
Pwebbz28's Avatar
Heli-coil is actually a good option. As far as size i cant say but i do know i have read a couple posts on this.
Old 02-23-2006, 09:53 AM
SUTTERERMAN85's Avatar
you can heli-coil it. it is really your only option other than taking off the head and welding it up and then retaping the hole.
Old 02-23-2006, 10:25 AM
TT-TECH Veteran
Inspector12's Avatar
I've heli-coiled a few of those and it is not that hard depending on where the location is on the car. If it is in the rear it might be hard to get the drill strait even with a 90*drill. And getting it strait as possible is a good thing LOL! I have the stuff to do it if you lived in the Houston area.
Old 02-23-2006, 03:30 PM
LS198Z28's Avatar
aight im gonna go out and helicoil it ill let you know how it turns out
Old 02-23-2006, 04:00 PM
| Powered by Satan |'s Avatar
damnit billy... quit breaking stuff!
Old 02-23-2006, 10:09 PM
LS198Z28's Avatar
it needed to be done i only dynoed 350 to the wheels so im going to get that thing up to 400 by the summer hopefully. the helicoil went well exept the insert tool thing was made out of plastic and f-ed up so i ended putting it in with a pair of pliers now i just need to put it back together. oh and do the other side.
Old 02-24-2006, 12:23 AM
Bad Blu Formula's Avatar
350 is no bueno out of that car man. Better clean that bitch up.
Old 02-24-2006, 02:08 AM
good to hear man! just keep us posted
