got a few problems, need help.
My car is currently throwing a few codes, 4 to be exact. 2 for the A.I.R. system cause my check valves are burnt to a crisp, 1 for and O2 sensors being fried, and another one for the MAF which is the one that concerns me. The code is P0102 to be exact. Something about MAF low input or something. Any ideas on what could be causing this code?
thanks,
Ryan
thanks,
Ryan
wrencher
Re: got a few problems, need help.
Haven't popped a engine sensor fuse have you? Anything that can cause the maf to have a low input fequency (the pcm knows about what reading to X- spect)if out of operational window pcm will set this code. No power , air leak in intake bellows, dirty or defective maf or a pcm failure can cause this problem.
P0102. I usually see this with dirty MAF thermistors (little wire doo-hickies inside the MAF). People go nuts with the K&N cleaning oil sometimes. This stuff will goop all over the thermistors and set this code. Try taking some electriclean to your MAF wires and see if that helps.
<small>[ March 04, 2003, 09:08 PM: Message edited by: NoGo ]</small>
Thanks for the help, I'll look at the fuses and try cleaning it. I took it off and looked at it. I do use a K&N filter, but I didn't see any goop on it, but i'll clean to to make sure.
Thanks!
Thanks!
