STS Help!!
STS Help!!
Im building a 346 long block with LQ9 heads, my compression should be around 8.9:1 Im also running an STS kit on this setup. I needed help picking a good cam to run that will still be smog friendly in CA. My plans are to run decent boost with 91 and run high boost with 110 octane. So far I was told I should run a reverse split cam 226,220,570,565,115 Im trying to get other opinions.
