Predator programmer special!
We are offering the Predator programmer for $419.99 and including a free 160 or 180 thermostat along with free overnight shipping in the continental 48 states.
Some features for the Predator include -
OBD-II diagnostic software (includes live data monitoring of MPH, RPM, IAT, ECT, LTFT, STFT, O2 voltage, timing, knock retard detection, as well as many other sensors
Eliminates CAGS (Skip Shifting) on the 6-speed manual transmissions
Revised Torque Management Settings for optimum performance
User adjustability. the user can set their own parameters -
Choose from DiabloSport's performance program, have a custom performance program made for you by a Diablo Tuner, or create your own:
a. Richen or lean fuel mixture
b. Advance or retard ignition timing
c. Raise and lower shift points in 10 RPM increments
d. Raise and lower rev limiter in 10 RPM increments
e. Reduce shift duration (time delay during gear change) (+/- 25% and anywhere in between)
f. Increase or decrease shift firmness (+/- 25% and anywhere in between)
g. Correct speedometer for gear changes and/or tire sizes
h. Turn on cooling fans at lower temps in incremental steps of 1 degrees (for vehicles w/ factory equipped electric fans)
i. Adjust top-speed limiters (eliminates on the Y and F-bodies)
The Predator is the most advanced tuning programmer available today. It has taken the hand-held programmer to a new level. You will notice quicker acceleration and better throttle response. If you have an automatic transmission, the Predator will also give you a firmer, more responsive shift pattern (gas vehicles only at this time). The Predator will raise your rev limiter as well as it allows you to raise your top end speed limiter if you have installed high speed rated tires.
A unique feature of the Predator is that is allows you, the user, to “fine tune” DiabloSports program. Since vehicles are located at different elevations or different weather climates, the way the vehicle responds to the DiabloSport program may vary (not all vehicles are exactly alike). Some vehicles will see better gains than others and some may see better (or worse) gains than advertised. This is due to the fact that not all vehicles respond exactly the same. Now, here’s the good news…If you're not totally satisfied with the way DiabloSport program performs, the Predator allows you to make your own adjustments to the program. For example: If you feel that the shift points are too firm, you can go into the program and lower the transmission line pressure (gas vehicles). If you feel that you can benefit from a higher shift point rpm, you can go into the program and raise shift points. If you feel that you will benefit from a few more degrees of ignition timing, you can go into the program and add some timing (gas vehicles). The Predator allows you to "fine tune" the DiabloSport program to meet your specific requirements.
The Predator has diagnostic abilities near identical to GM’s Tech2 software. The predator will allow you to read diagnostic trouble codes (DTC), erase DTC’s and perform live data monitoring. You can monitor your engine sensors while driving your vehicle and much more.
The Predator will save the original GM program so if at any time you want to go back to the original factory specifications, it will allow you to do so.
Have a good day,
Tom
Have a good day,
Tom
Re: Predator programmer special!
Predator Overview
Predator FAQs
Those links should answer your questions. It looks like it adjusts fuel/spark across the RPM range at WOT, not on a per-RPM basis:
Power Enrichment (Fuel): Will adjust from -5% to +5% at WOT
Spark (Timing): Will adjust from from -10% to +10% at WOT
Predator FAQs
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by hawkls1:
<strong> can you adjust air fuel and timing by rpm. and if not how do you adjust it.thanks </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The Predator's base tune adjusts for the whole powerband. The end-user is only able to adjust the fuel and timing for power enrichment mode (WOT). DiabloSport does do custom tuning as well.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> DiabloSport does do custom tuning as well. [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What kind of custom tuning can we now do?
Are we able to adjust for a cam install?
