Suspension & Brakes - what exactly do LCA's do?
View Full Version : what exactly do LCA's do?
andypdbz
02-24-2006, 09:43 PM
what do the lower control arms do?
and how do they work?
and what about subframe connectors?
sorry for the noobish question :P
FloydSummerOf68
02-24-2006, 10:05 PM
LCA's help your 60' drastically by applying force down on the rear.
SFC's help to strengthen up your frame. This is a great mod for T-top or Verts.
andypdbz
02-24-2006, 10:10 PM
which would be the best deal on LCA's?
and how much of a hassle are they to install?
DONAIMIAN
02-25-2006, 12:02 AM
you can do LCA in a matter of mins. Most time consuming part was jacking the car up. The LCA's in conjunction with the PHR basicly locate the rear end under the car front to back and side to side.
andypdbz
02-25-2006, 05:38 PM
i see....
so any recommendations as to which ones to purchase?
02SS0384
02-25-2006, 06:21 PM
LCA's locate the rear end forward and back. A PHB locates the rear end side to side.
As far as which one's to purchase first you have to decide on end type, do a search on end types because there is a variety of combinations of rod, poly and rubber ends. Each has it pro's and con's. Then check out the sponsors and the GP section. I went with poly/rubber LCA's because I wanted minimal noise. Both LCA's and PHB are very easy to install.
SFC's "complete" the lack of a full frame on a uni-body car (f-bodies). They keep the body from twisting under torque. Again you have a few options (lubular, boxed...weld-in, bolt-in). I've got a custom set of boxed welded in.
