Intake comparisons > LS1 vs LS2 vs LS6 vs FAST w/ 78mm & 90 mm
You may have already seen this, but, if you're like me, I had not known this until today. I see a lot of people buying the 90/90 setups for cars around or under 400/RWHP/RWTQ. It looks like a waste of money after seeing this. The LS6 intake outperformed in low and mid-range hands-down over the 90/90 setup. Not a whole lot was gained up top, either.
To think I was about to spend all that money to sacrifice low and mid-range power for a little up top above 6000 rpm. That's where my A4 shift points are set. I guess my $1,400 will go towards the 100-500 progressively controlled Direct Port setup with my LS6 Intake. Of course, if you need it up top more than you need power down low or in the mid-range ... with a larger bore engine ... guess you need the 90/90 setup.
http://www.gearchatter.com/viewtopic10974.php
To make sure no-one freaks out, those were engine dynos. Even the best 432hp peak equates to only 375rwhp (at best on an M6). On top of that, this was with stock unported *LS1* heads.
I would say that for cars *UNDER* 400rwhp its a waste. 400rwhp and above will likely benefit greatly from the 90/90 setup, especially if you have higher than stock shift points.
!LS1 11 Second Club
Originally Posted by Cgillies86
If the LS6 intake manifold had a ported throttle body, I bet the peak would of been a bit closer to the peak of the LSX.
http://www.tpis.com/index.php?module...+Throttle+Body
heres what i have to say... if you have the funds then go for it.. i just orderd mine if i gain then i do if not oh well... ill be doing heads and a new cam later this year.. ill gain from it sooner or later
and ill admit i NEVER thought id be spending this much coin on an intake and tb.. even my friends were talking shiet said i they thought id never "waste" my money on a FAST 90
Interesting results, good find.
If the test engine had a larger cam and well ported heads on it the outcome would have been closer OR if the engine was of larger displacement (383" or bigger) the FAST setup would have had the upper hand.
Wish the FAST intakes were cheaper
Originally Posted by BADFNZ
And I bet if the FAST intake was ported, which everyone does, the numbers would have been even higher.
Low-midrange on a 346/347 cube would prob even lose more down low/midrange from porting the 90mm.
The whole point for me posting this was to address the 400 RWHP range on a mildly modified LS1. The differences in various intakes was my point on this power/motor environment ... not the what-if's. I think we all know the 90mm/90mm is the absolute best way to go on larger bore motors making moprepower, however, you'd still be giving up power/torque down low. Then, again, on a 402/408+ stroker, who would really care unless you're trying to loft your car into a vertical wheelstand. That's impressive but doesn't win races.
I appreciate everyone who has responded so far. Keep it coming.
not too sure about those tests, it looks a similar test done by Hot Rod or CHP or another mag, with similar results....all tests were done using stock pcm with no tuning, every one knows to get the most out of a mod tuning is a must. I believe the results would be different if each combo was tuned for the specific mod, but maybe leave timing alone for comparison sake.....
This looks like the article that appeared in Street Thunder magazine (same types of tests).
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
Here are a couple other discussions on this article:
https://ls1tech.com/forums/generation-iii-external-engine/432100-ls6-intake-vs-fast-lsx.html
https://ls1tech.com/forums/generation-iii-external-engine/436779-tpis-oval-ls6-throttle-body.html
Another person posted a scan of the article, not good quality, but just FYI:
http://www.eadperformance.com/intakearticle/
I like these tests for another reason: there has been much negativity with respect to the LS2 intake, but with no supporting facts. You would hear "the LS2 flows worse than the LS6" or "you lose hp with the LS2 intake", then you would ask for the data, and the response would be "oh, it's over in the dyno section". When you search the dyno section, it's someone stating it but not supporting it.
Originally Posted by curtisad
I wish they had a dyno chart showing the differences between the LS1 intake versus the LS6 intake!! I am ding that swap in April
