write up on intake install needed
Hey all, i had about the RK Sport SS hood and i just put it on the car. I was about to do the intake but it seems kinda complicated. I have directions but i was wonderin if anyone had any pictures to go along to make sure i dont screw up bad. Im new at this kinda ****.
Thanks
Thanks
thanks for the reply, but i dont think thats the write one...
the directions i have start off like..
1. remove airbox lid, MAF n tubing
2. Using hacksaw blade, cut out bottom of filter base assembly
3. remove plastic air deflector panel from in front of AC condensing coil
4. cut out part of the air deflector panel
5. reinstall air deflector
6. remove the three 8mm bolts in the mid section of the lower air deflector; remove 1o mm bolt that secures the brace to lower portion of car
7.Assemble the air duct with the ram air plate
8. slide that through the hole in the air deflector.
9. etc etc
9. etc etc
i honestly have no idea what it is i am changing. it came with the SS hood and it says whisper ram air induction.. any other info i have is that it comes in 3 parts, all made of sheet metal...
sorry im such an idiot when it comes the mechanics but thats why i'm here... tryin to learn
