76mm or 80/88mm..
Old 02-26-2006, 04:22 AM
MyWs62FaST4u's Avatar
Default 76mm or 80/88mm..
is the 76mm too small? not sufficient enough? im building the 418, we all know, but dont wanna smoke up when i shoot from a stop, so i figured the boost coming a lil bit later (80/88mm) would be hot for the roll race, or a dead stop... will it back up the 418cid??? Im shootin for the t6 flanged...
Old 02-26-2006, 09:48 AM
smokinHawk's Avatar
id probably do an 88 t6 flanged one with an engine that big
Old 02-26-2006, 11:44 AM
Josh@KY-Turbo's Avatar
i am going with a T88 on my 408. unless i do twin T70's instead...
Old 02-26-2006, 03:27 PM
CarolinaWS6's Avatar
im going to try a t80 on my 408 first if it does work out im going to modify my kit alittle a run a t88
Old 02-26-2006, 06:13 PM
NA$TY-TA's Avatar
Id go bigger then that..... 91mm GT55... comes to mind.....
Look at the flow of that motor and the Compressor maps of the turbo's your looking at.... you are going t want to keep back pressure in mind when choosing what turbo.
Kyle
Old 02-26-2006, 09:07 PM
RUSH's Avatar
Kyle
Yes the 91mm wold ring some bells and your set up could defintly handle it. going with a smaller housing would assist the lag.
Old 02-26-2006, 11:29 PM
91mm? ok. But would that be good for a cruiser??? lol! I wanna pass the gas station maybe once or twice in a week, instead of pulling into it... I am gonna drive this thing alot, all over actually..eh, I guess ill be ok. i am also planning to run the 3 bar program and ditch the Mass air..
Old 02-26-2006, 11:47 PM
ABeasst's Avatar
I'd run a 88
Old 02-27-2006, 12:01 AM
So heres my cut, looking for a viper killer... lol, simply said... 418cid and 88mm turbo, who cares about true times, as long as im not in the mid 11's...HA! I just wanna lay some exotics and high end domestics out to dry...
Old 02-27-2006, 01:12 AM
ill probly end up running a T88 with a T6 flange
Old 02-28-2006, 11:08 AM
Stupid Boost's Avatar
Go with the S88. Heck they are tough enough we are ordering them for 150+psi compound diesel setups and they spool great for the amount of flow. Also the Gt55 is huge in comparison. Its a tough fit indeed.
Quick Reply: 76mm or 80/88mm..
