Puting In 02 Ls6
Puting In 02 Ls6
Ok I have a 2001 SS m-6 and am putting a new 02 LS6 engine In,, What type Of programing do I need If any?
Can I just flash pcm to a stock Z06??
Thanks,
Thanks,
Re: Puting In 02 Ls6
The differences between stock LS1 and LS6 programming are small and are related mostly to the larger LS6 MAF sensor. If you keep your LS1 MAF sensor the LS6 will be ok without any PCM changes. This would be a simple first step. If you later want to install the larger MAF you will need to update the MAF table.
"flash pcm to a stock Z06" is not exactly meaningful because the PCM contains information related to more than just the engine.
do you know what pins you read across for the voltage? or is their only 2? is this volts or milivolts? thanks. my car is ins storage still and i got know visual reference so bare with me. <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
