trann cooler problems
ok well i went by the install write up and im having a problem.. when i push these black ties threw the cooler and the rad. they come out and hit the fan shroud.. well i was like ok ill just take it off but on the 4 sides there seem to be like hook thangs where u have to slide it up and detach the fans...but i pull up and nothing moves..and i really dont want to drain the coolant and everything to remove these fans just to attach this cooler to the car..what can i do..the car is a 99..and on this site http://www.zmydust.com/trannycooler.html you can see some bolts on the fan but i dont think my car has them..sence hes working on a lt1 car...help someone...
I just moved the cooler around until I got the ties to go trough the fans. Then with some creative maneuvering and some cursing, I was able to get it all strapped up and cut without interfering with the fans.
