remote turbo question
i was wondering what could be used to pump the oil from the turbo back to the motor, im thinkin g about fabbing up my own remote turbo. can the oiling system from sts be purchased separately? what could be used to get the turbo oiled back there. thanks
Although I'm a front-mount, I tried purchasing a scavenger pump from STS. They wouldn't sell it to me seperately. Then, my installer found one from a trucking company (?). The brand is High Flow (not related to the LS1tech sponsor). It's noisy as ****, but it does the job. Try calling STS and see what they tell you? You never know. I think all turbo set-ups should run a pump... Not a puff of smoke from my car, not even at WOT.
Theres a 12v fluid circulation pump made for differential/rear end cooling and turbo oiling, Flow rate 1.0-2.0 GPM and up to 54 PSI. Lemme dig up the link.
its really loud and kind of costly ~$180
Mocal is the name of the pump. I am using it for my turbo.
http://racerpartswholesale.com/ I purchased mine here
Originally Posted by chuntington101
has anyone run a STS with a dry sump setup????? then you could use one of the scavnge pumps to pull oil from the trubo/s??????
and these thinga are VERY reliable.
Chris.
Chris.
Originally Posted by fletchls1
If the rubber grommets are used, it is fairly quiet...It is still a vane pump...Not really all that fond of them but for the short trips the pump has on it, it is still alive...
what other pumps are out there?
