Evans Sale-Before big price increase
Get your Evans parts and coolant before the prices rise dramaticly. They have seen a large increase in the manufacturing parts and will be increasing there product line.
Building that big bad *** high HP monster? Keep it under control with the best products on the market Evans Cooling Systems. These highest quality pumps and components and spesificly designed to keep heat under control and flow 30%+ more than stock pumps. For the next 2 weeks I will run 15% off all of there products...Do not see your application please call I will get you a price they have hundreds of pumps and components.
Evans Truck 99-05 LS1 LS2 Waterpump $475 Sale $403.75
Evans Corvette 97-05 LS1 LS2 Waterpump $475 Sale $403.75
Evans GTO 04-05 LS1 LS2 Waterpump $475 Sale $403.75
Evans F-Body 98-02 LS1 Waterpump $475 Sale $403.75
Evans New Corvette LS1 Radiator $500 Sale $425.00
Evans T-stats for LS1 160/180 $55 Sale $46.75
Coolant NPG, NPG+, NPG-R $25.50 a gallon
Call or email if you do not see your application.
Nate
Nate
The Evans Pump/TStat are great for increased cooling - I've had these on the car for at least a year now and the temps are always steady - I got the 'JetHot' like powdercoating for that xtra bling on mine...
-Jay-
-Jay-
Mods? There are no mods needed to run there coolant you just need to flush out all the water mix coolant. They sell a prep fluid to do that. Evans actually designed the LT1 water pump for GM.
Nate
Nate
You can run whatever you want with there pump. There are just some added benifets to using the waterless race coolant and has been know to lower temps even more.
Nate
Nate
Nate-
Need to pick up some NPG+, Flushing Fluid, and Rad Cap - I've been running the Dexcool with the Evans pump - want to run the Evans Coolant starting this season when I install new rad.
You open for phone orders on Saturday (today)?
-Jay-
-Jay-
Nate
Nate
Check out Evans site. Seems they designed a little bit more than the LT1 water pump .
Ryan
Hey, I just got my pump the other day and it looks sweet. I am just going to run normal dex-cool. Is there anything I have to do to the pump or anything before I start using the dex-cool in it? Let me know if you can because I am going to put it on teh motor this weekend and want to be sure of everything.
Let me know.
Thanks.
Let me know.
Thanks.
Nothing needed to run Dexcool - just install pump, fill system and bleed properly. Most important factor in T/A cooling system is to ensure there is no trapped air in the cooling system.
-Jay-
-Jay-
