Local BBC
Local BBC
.. for sale.
It's got the following highlights:
1973 454 block bored .060 over, 4 bolt caps and line bored. Lifter Valley is polished and has screens and magnets epoxied in.
427 steel crank (.010/.010 and crossdrilled)
GM Truck rods that have been shot peened, polished, sized, and balanced (sizing and balance by Bliss in Spanaway)
TRW Forged Dome pistons L2308AF060 (full floating pins) These have a 50cc dome and should be 11.66 to 1 compression with 117cc heads.
Manley true roller timing set with torrington bearing
GM 781 Iron oval port heads ported by PDQ.
2.19/1.88 stainless valves.
Comp Products electro-polished congo roller valve spring (for big mechanical roller cams).
Trick titanium retainers with 10 degree locks.
Pushrods .080 3/8 (Comp Products/Howards Cams ultimate)
Schneider Custom Mechanical Roller Cam (requires bronze gear on distributor!) I:266@.050/E:270@.050 Lobe sep: 108 Intake centerline:106 Valve lift: I -.655 ; E - .663
Schneider light weight solid roller lifters
Oil pan is a typical Moroso knockoff that has the gold rear sump pan that flares out slightly to each side.
ARP Main and Head studs
Holley strip dominator intake
All in all, a VERY good deal for only $1450.
Let me know if you are interested. I'll be happy to get that 6 square foot area of floor space back
