Help!! Im leaking Air Bag Fluid!!
Old 02-28-2006, 11:54 AM
2kSnakeEater's Avatar
Exclamation Help!! Im leaking Air Bag Fluid!!
I was driving today and I noticed alittle bit o fluid coming out of the lower left corner of the pass. air bag, and I thought I would post.
Old 02-28-2006, 11:57 AM
thunderstruck's Avatar
do you have t tops?
Old 02-28-2006, 12:00 PM
why yes I do!, its an oily fluid thought. Not water, and its coming out of the bottom left corner, I figure it could be some armor all.
Old 03-08-2006, 08:44 PM
andrew20's Avatar
i dont think air bags have fluid to leak
Old 03-08-2006, 11:55 PM
anthonyz281999's Avatar
did u check ur head light fluid too ??? jk....i didnt think airbags had fluid....more of just compressed air ...but somone correct me if im wrong
Old 03-09-2006, 02:45 PM
Black1997T/A's Avatar
Airbags do not have any fluid, they have a small capsul about the size of dime, that consists of a rocket fuel type of combustible.
Old 03-09-2006, 03:12 PM
YoMommasTA's Avatar
and corn starch as a lubricant for the bag,thats the white stuff all over the place after the air bag deploys.
Old 03-09-2006, 08:12 PM
Zymosis's Avatar
My turn signal fluid leaked too, I wondered why it was blinking so slow the last couple weeks
On a serious note, no fluid, I'm guessing your t-tops or window seal is leaking some water.
Old 03-09-2006, 08:19 PM
slowpoke96z28's Avatar
or a plugged evaporator core drain. i thought this thread was a joke in the lounge. i had to look twice to make sure i was still in the right forum.
Old 03-10-2006, 10:09 AM
black01_WS6's Avatar
you probably got water from your t-tops on it and made your armor-all go in the cracks, and now its coming out. so its not a problem.
Old 03-10-2006, 11:15 PM
2002_Z28_Six_Speed's Avatar
Sodium Hydroxide
Old 03-11-2006, 06:32 AM
Timonator's Avatar
My guess is a leaking heater core.
Old 03-11-2006, 10:03 AM
ashade98's Avatar
Old 03-12-2006, 10:11 PM
'99slobird's Avatar
I'd say the heater core or a water leak around the t-tops or windshield.
I'm an industrial maintenance technician at a plant that makes airbag inflators for pretty much every major auto manufacturer (excluding Ford). Airbags don't have any type of fluid in them. An airbag inflates due to an electric pulse that detonates a "enhancer" which is kind of like a blasiting cap, then ignites a gas generant material, that is basically a stabilized version of rocket fuel (kind of like it's mixed with play-doh that has dried out). This is just for driver's and passenger's side air bags, side curtain bags are filled with a mixture of helium/argon, or CO2/argon, a light load of the gas generant, and the electric device that starts the reaction. Pretty Neat, we get to blow them up all the time at work. We have chambers that are built to test them by measuring pressure when they inflate. They make a pretty good "pop", and when the seams of them are welded (by lasers to reduce heat), every once in a while one that isn't sealed all the way will go off in the machine, that'll really wake you up.
Old 03-12-2006, 10:40 PM
That's cool! Wish you had videos!
Old 03-14-2006, 03:00 AM
'99slobird's Avatar
If I had them, they'd probably fire me on the spot. This place is tight lipped about the process that goes into production. They're worse than the baked bean people on the commercail with the golden retriever.
Old 03-15-2006, 08:23 PM
YEA! You have a good job right there. Plus lots of job security since some cars have 8 airbags in them now. Absurd!
So, an airbag has to be 100% guaranteed to work right? Glad you guys are on the watch!
I bet you can't go into any airports right after work though!! HAHAHAH
Old 03-16-2006, 04:05 AM
'99slobird's Avatar
Yeah, if they loose an initiator then no one leaves until it's accounted for. Every part is weighed and tracked by a serial #, all the propellant weights, press heights, pressures, lot numbers of parts that they're assembled from and so on are recorded in the event that a failure happens, they'll be able to track down the cause.
And about the job security, our orders have went up over 200% in the last year. The place has doubled in size in the last year, and added three new lines.
Old 03-16-2006, 04:53 AM
cantdrv65's Avatar
Wink
A buddy at a dealer saw a newb mechanic take an impact wrench to loosen the airbag module....His head was also in front of the steering wheel. Needless to say he got knocked the f--- out!
Old 03-17-2006, 01:38 AM
Why did the impact wrench make the airbag go off? It is sealed and would take a large charge to ignite the starter. I think the deployment voltage is 24 volts. Just asking. Wondering if ambient voltages could make it go off. Not seeing how a tool that didn't place a voltage acrost the starting coil made the airbag go off.
He must have really not of known what he was doing!!
